メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
20回答 すべてを表示
Is my backlight going out?
The top of my screen is noticeably dimmer now than in the past. "Easy," I thought, "it's the top backlight going out!" But now I'm not so sure. See, whenever the iMac wakes from sleep, the screen is nice and bright for about ¼ second before going back to its now-normal dim state.
Can anyone tell me what's going on? Is my backlight in fact going out, or is something else going wrong? I've checked the brightness control in Displays, and calibrated the screen, with no improvement.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Bump. Anybody? Bueller?
さんによる
コメントを追加
2件の回答
ベストアンサー
Sorry I missed this the first time :-(
Sadly your system uses CCFL's which over time do fade in brightness as they get close to burning out. Just like your office ceiling CFL's do.
While you can still get replacement CCFL's they are a bear to replace and if you're not careful easy to break as well. Here's a good guide to follow: Removing CCFL from iMac 20in LCD CCFL assembly. If you've never attempted anything this complex you might want to opt out and just replace the complete LCD unit. While more expensive it is a lot less work and risk. Here's the IFIXIT guide: iMac Intel 20" EMC 2133 and 2210 Display Panel Replacement.
iMac Intel 20" EMC 2133 and 2210 Display Panelの画像
ガイド
難易度:
中レベル
5 - 20 minutes
iMac Intel 20" EMC 2133 and 2210 CCFL assemblyの画像
ガイド
難易度:
難しい
1 hour
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
But does that explain why the screen will go back to its old brightness for a second after it wakes up?
さんによる
Yes, just like a ceiling CFL's they react the same way.
さんによる
CFLs slowly brighten as they warm up, not immediately dim right after they're turned on.
さんによる
You're over thinking this ;-} When the bulbs are just about worn out they get brighter.
さんによる
And then immediately dim? I've never seen that.
さんによる
1以上のコメントを表示
コメントを追加
The backlight might be fine. You may need to replace the inverter. I would suggest trying a new inverter before sourcing and replacing the LCD itself. Here is a guide on how to swap it out: iMac Intel 20" EMC 2133 and 2210 Inverter Replacement
iFixit does not have any in stock at the moment, but you might be able to find one on PowerBookMedic.com, Ebay, or Amazon.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If it was an inverter issue both CCFL's would react in the same way.
さんによる
コメントを追加
回答を追加する
Calion さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 386
