Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
このアンサーは役に立ちましたか?
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
このアンサーは役に立ちましたか?
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
このアンサーは役に立ちましたか?
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 5,022
1件のコメント
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
Taylor Arnicar さんによる
