メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
締切られた回答
I need help Identifying a blown component on my Logic Board
There is a component on my logic board that has blown it gives power to the bluetooth and isight I'm not sure if it is a resistor or capacitor I need someone to identify it for me or can I have the schematic for the camera circuit.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
WJL, any chance you can post an image that is a bit clearer and zoomed out as well as mark the component. I can not make out any detail on the image you posted. I suppose that your component is in this area
update
that is reference designator C3452 which is a 0.1Uf 10V 20% capacitor in a 0402 package. Appears to be a pretty common stock item at places like digikey.com or mouser.com
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
yes it is in that area but the cameras I have are bad at focusing ill circle the component
さんによる
@oldturkey03 I have circled the component that is blown
さんによる
@oldturkey03 THANK YOU SO MUCH!!!! Im going to order everything needed to fix it hope to get bluetooth and the isight working.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 115
