The battery seems to not charge
Quick start guide states pulsing orange light should show when battery charging, but nothing shows. Blue light shows when turned on , plugged in , however.
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
I have a similar problem. Orange LED never appears (blinking or stable).
I suspect the battery is bad, because the projector works when powered by my laptop's USB port.
My plan is to leave the unit in charging mode (power off, charging from wall outlet) overnight and see if anything changes.
このアンサーは役に立ちましたか?
Hi, I have the same problem, is it working after you charge it overnight?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 608
