メインコンテンツにスキップ
The Nokia N900 is a mobile Internet device and smartphone from Nokia that supersedes the N810.
How to open my Nokia N900?
I am having problems with the turning control and the virtual keyboard in my Nokia n 900. Please suggest a remedy for that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
6件の回答
there are a few guides on youtube
two of them are here and here
and here are a few informations about the keyboard issue - hope this helps
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
nice links +
さんによる
コメントを追加
最も参考になった回答
I open mine all the time! When I get around to it I'll make a teardown or something.
Anyway, when you open the battery cover, there are four phillips screws, relatively small. I think I used PH0 screws. Then the bottom ones (close to the MicroSD) are torx, I believe they are T5? Anyway unscrew all of that, pull the display out, and the keyboard should just pop out.
Happy to see another Nokia N900 user!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ for the research (engadget link in the comments)
さんによる
コメントを追加
any way to install a different 3g chip attenna so we can take advantage of att 3g services?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thats impossible, its in the hardware and its part of the wiring of the entire phone. To change this you must get microscopic tweezers and copious amounts of germanium and other precious metals. And an extremely small soldering iron.
And in the future you should make a new question as this is not an answer.
さんによる
コメントを追加
How can I repair the Mini USB port, it loosened after few weeks of use..just like this http://talk.maemo.org/showthread.php?t=5...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what about warranty?? - every nokia stor with a service level 2 can fix it - as long as there is still something to solder it on. to do that on your own, you would need a hot air soldering station or a smd soldering iron
さんによる
http://www.engadget.com/2010/02/10/nokia... Bring it to any Nokia store or ship it to their service center. Its a known defect in N900s shipped early this year.
さんによる
コメントを追加
mic
Update
mic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Repair shop mailing address
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rajesh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 14,017
