メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
iPod sometimes skips songs
My iPod generally works fine, but sometimes my iPod will play around 3-5 seconds of a song, pause for a couple seconds, and then skip that song and proceed with playing the next. Has anybody had this problem, or does anybody have any ideas of what the problem might be? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
does this always happen with the same songs or is it completely random ?
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
It's completely random. I probably listen to around 20 songs per day from my iPod, and it happens every few days.
さんによる
there are a few possible solutions for that problem. i would try the following steps (one at a time ;-) ) hard reset, restore, checking the hdd for errors (depending on your computer win/mac). the skipping problem comes sometimes from failing/fragmented hard drives, a desoriented iPod or the iPod has problems with vbr encoded tracks.
さんによる
I've already tried hard resets, and I just wiped my iPod and am restoring everything. I'll let you know how that works out.
さんによる
ok, thanks ;-)
さんによる
I'm listening to my iPod to see if I can hear it again. I just heard a slight pause, but it didn't change songs (this sometimes happened before, but changing songs after the pause was more common). This isn't sounding good :/
さんによる
2件以上のコメントを表示
コメントを追加
try checking those songs in iTunes mine was doing the same thing and i went into iTunes and tried to play them, and it played the exact same amount that it played on my iPod and skipped to the next song. I just reimported the songs that it was skipping and it fixed everything. Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The songs play fine in iTunes, thanks for the idea though.
さんによる
コメントを追加
回答を追加する
Adam Hintz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 2,878
