メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
締切られた回答
Battery sometimes fails to properly charge
I've had this computer for a couple years now, and it's still running strong. The battery still gives me 4-5 hours charge, which is fantastic. The only problem is that sometimes the battery refuses to charge when my laptop's plugged in and the battery still has a good amount of charge (somewhere between 90% and 50%). Also, if I'm charging the battery from a lower charge, it sometimes refuses to finish charge - it says "Finishing charge" (or something like that, I'm not looking at it right now). What do you guys suspect the problem is?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I read somewhere that this is a known problem with the logic board. My macbook 2007 suffers from the same problem.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
sounds strange - maybe the battery gives wrong data to the logicboard
did you try coconut battery to determine the original capacity vs. the current capacity
are you able to try a different battery - maybe it works normal with a different one (or not - that way you could rule out a battery problem)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I haven't attempted to use another battery, but my sister has the same style MacBook, so I'll definitely give that a try when I get the chance.
さんによる
I haven't gotten any resolution with this, but I don't have the problem anymore. Perhaps just cycling the battery several times / the passage of time / software updates fixed it. Either way, I'm upvoting this answer so that the question is no longer "unresolved".
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,148
