メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
20回答 すべてを表示
締切られた回答
New hard drive-now its really not working.
Ipod classic 6th generation 160gb
I assumed my hard drive died, so I purchased a new hard drive. I followed the guide on here and after putting everything back together, the red X appears.
The ipod will not go into disk mode. When I run a test on the hard drive in diagnostic mode, it says "error diag halt."
The hard drive does not make any sounds when the ipod turns on. I connected the old hard drive and it doesn't make any sounds either.
Is it possible that I damaged the hard drive cable?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hello,
i had the same problem a couple of times, sometimes it was a damaged hard drive cable, but sometimes it was the logic board.
Its hard to tell, if its the cable or logic board. But as the cable is not that expensive, i would give it a try and buy a new cable.
Good Luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,275
