メインコンテンツにスキップ
必要な工具と部品
ツール
もっと見る
この分解は修理ガイドでは ありません。 お持ちのSamsung Galaxy S23を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Galaxy S23 Teardown, Remove the rear glass: 手順 1、 2の画像 1 Galaxy S23 Teardown, Remove the rear glass: 手順 1、 2の画像 2
    • First we heat the rear glass of the phone to melt all the adhesive that glues the glass to the rest of the phone. We can do it either with an iOpener or with a heat gun.
    • Now with a flat object or with an opening pick we cut the remaining adhesive by inserting it between the glass and the rest of the phone and passing it along the entire edge.
    • Now we can raise the back panel and we're done.
  2. Galaxy S23 Teardown, Remove the Wireless Coil and NFC Antenna: 手順 2、 1の画像 1
    • Unscrew the 6 Phillips #00 screws that weld the wireless charging base and the NFC antenna.
    • Disconnect the connector connecting the two antennas and remove everything.
  3. Galaxy S23 Teardown, Disconnect the Battery: 手順 3、 1の画像 1
    • Unplug the connector to disconnect the battery.
  4. Galaxy S23 Teardown, Unscrew the Charging Board: 手順 4、 1の画像 1
    • Remove the 7 #00 Phillips screws that secure the charging board to the rest of the phone.
  5. Galaxy S23 Teardown, Remove the SIM: 手順 5、 1の画像 1
    • Use a fine tool to pull out the SIM tray.
  6. Galaxy S23 Teardown, Remove the connectors: 手順 6、 1の画像 1
    • Remove the connector with your fingers or a flat tool.
  7. Galaxy S23 Teardown, Remove the Front Camera Protector: 手順 7、 1の画像 1
    • Unscrew the 5 Phillips #00 screws that secure the front camera protector to the rest of the phone.
  8. Galaxy S23 Teardown, Remove the Front Camera: 手順 8、 1の画像 1
    • Unplug the front camera connector and remove it.
  9. Galaxy S23 Teardown, Remove the Rear Cameras: 手順 9、 2の画像 1 Galaxy S23 Teardown, Remove the Rear Cameras: 手順 9、 2の画像 2
    • Remove the two Phillips #00 screws that secure the rear camera protector to the rest of the phone.
    • Unplug the three connectors of the three rear cameras and remove them.
  10. Galaxy S23 Teardown, Remove the Charging Board: 手順 10、 1の画像 1
    • Unscrew the three Phillips #00 screws that secure the docking board to the rest of the phone and then remove it.
  11. Galaxy S23 Teardown, Remove the battery: 手順 11、 3の画像 1 Galaxy S23 Teardown, Remove the battery: 手順 11、 3の画像 2 Galaxy S23 Teardown, Remove the battery: 手順 11、 3の画像 3
    • With the special tab, detach it and pull to facilitate the removal of the battery.
  12. Galaxy S23 Teardown, Remove add-ons: 手順 12、 2の画像 1 Galaxy S23 Teardown, Remove add-ons: 手順 12、 2の画像 2
    • Remove the volume keys motherboard and them too.
  13. Galaxy S23 Teardown, Finished: 手順 13、 1の画像 1
    • We have completely disassembled the new Samsung Galaxy S23.
作成者
6人の作成者と共同で作成されました。
Andrea Alfani
メンバー登録日: 04/20/22
8,287 ポイント
5のガイドは作成済み
チーム
Kid fixers Kid fixers人のメンバー
Community
184 メンバー
256のガイドは作成済み
8 件のコメント
You beat iFixit to the punch! Nice work. They're really falling behind. Good thing we have awesome users like yourself! Thank you!
Damien Lobb - 返信
Thank You so much i really appreciate it thank you so much i really appreciate it
Andrea Alfani -
Will the microphone get damage if I wrongly insert the sim pin into it?
apple terr - 返信
Mine did not damaged, all works properly)
Ramil Salakhetdinov -
Will there be galaxy s23 a teardown wallpapers?
Hamlo Take - 返信
Any advice how to reattach the back glass?
Joseph Smith - 返信
is the battery fixed on the “hook and loop” fasteners
Andy Zhang - 返信
コメントを追加
統計データ:
過去 24時間: 23
過去 7 日: 172
過去 30 日: 672
今までの合計 41,784
