MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Silver
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Black
$39.99
$39.99
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
Replace a broken, damaged, or otherwise underperforming fan for your MacBook Pro 13" Unibody (Mid 2010-Mid 2012) or MacBook 13" Unibody (all models) with this part.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
  • Fan
  • Surrounding metal bracket
ビデオをインストール
互換性
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Unibody Model A1278
2 GHz
2.4 GHz
MacBook Unibody Model A1342
2.26 GHz
2.4 GHz
4以上のデバイスを表示する
修理にまつわるストーリー
問題
The fan sounded like it was dying.
As I was leaving one day, it started running, and I was sure that someone was outside using a weedeater. Then I remembered it was winter and snow was everywhere, so that probably wasn't the case.
修理
Pretty painlessly. I read some reviews hearing that it didn't go as w . . .
問題
I suppose my computer is ancient considering many machines are replaced at 2ish years. Anyway, fan was making terrible clicking/rattling sounds after a suffering a light drop from a low bed onto carpet.
修理
Easy peasy, lemon squeezy.
アドバイス
None. If you know how to use a screw driver, you can make this repair.
問題
The fan had been making a loud grinding noise. It also couldn't reach it's max RPM.
修理
It was very straightforward.
アドバイス
Be slow and patient; the connectors are very delicate. Also, keep track of the screws!
問題
Wife's Macbook Pro 13" fan stopped working
修理
Literally took off the Phillips screws holding bottom cover, took 3 Torx 6 screws out, unplugged fan from board, took out fan, put new one in, plugged into board, put Torx 6 screws back in, and put Phillips back in. Worked like a charm.
アドバイス
Screws had tiny bump o . . .
問題
The fan was getting noisy but still working. I knew its days were numbered
修理
super easy. While i was in there I decided to upgrade the HD to an SSD also. With the tutorials on Ifixit it was all super easy.
アドバイス
Don't be afraid to try repairs on your MacBook Pro. It's much easier than you think with the tutor . . .
問題
My MBP has been making this grinding noise that I originally thought was the HDD failing (again). Turned out it was the fan going bad. When I ran a YouTube video my CPU temperature spiked to high 80's and you could hear the fan screaming for mercy. lol :)
修理
The most difficult part of the repair was wa . . .
問題
The fan had completely quit in my 2012 unibody macbook pro and as a result it was overheating and slowing the cpu to a crawl during taxing graphical work.
修理
The new fan fit perfectly and works perfectly and silently. I'm far more confident in its brushless motor to hold up.
アドバイス
The fans don't come with hard . . .
問題
My fan was making my MacBook sound louder than a blender!
修理
Super easy and straight forward.
アドバイス
Don't be afraid to make your own repairs. I recently also double the memory sticks on my MacBook and it is now nice and quiet and lightning fast. Having said the, do know your limitations.
問題
The fan was noisy, and it sounded like it was on the way out
修理
All good until it came to levering the fan connector out with the spudger. Then -- as predicted in the instructions -- disaster! All four pins from the logic board sheared off, firmly in the fan connector. Fortunately my local computer tech . . .
問題
The fan was beginning to make a screeching racket and the mac case was getting hotter than it ever had before, then it went quiet and made no noise! So after conferring with a friendMacGuru I presumed that at least the fan could do with replacement immediately lest I need to replace the lot imminent . . .
もっと表示する
