はじめに
MUST READ
Use this guide to replace the Lightning connector assembly in your iPhone XS. If you've tried cleaning the lightning port to no avail, replacing the Lightning connector can solve charging and connectivity issues.
The internal speaker connector is also part of this cable, so you will also need to replace this (or your speaker) to resolve sound issues.
Additionally, the guide steps below lead you up to the part where you remove the Taptic Engine, so please refer to the video after those steps. Please also look over the video before opening your phone just to get two perspectives of the disassembly process.
必要な工具と部品
ビデオの概要
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Remove five screws securing the logic board connector bracket, of the following lengths:
Three 1.0 mm Y000 screws
One 1.3 mm Y000 screw
One 3.7 mm Phillips screw
Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
One 1.0 mm tri-point Y000 screw
Two 1.3 mm Phillips screws
One 1.7 mm Phillips screw
One 1.8 mm Phillips screw
Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
3 の人々がこのガイドを完成させました。
4 件のコメント
Is this guide still planned? Are there any other guides which get close to the lighting connector? I have done one lighting connector before. It is the last part, which makes it a very difficult repair. I have an iPhone Xs A1920 which needs this repair. I would be interested in a collaboration.
