はじめに
このガイドを使用して、iPhone 14 の割れたラウドスピーカーを交換します。
このガイドは A2882 (国際モデル) を使用して作成されています。他のiPhone 14モデルを修理する場合、見た目に多少の相違があるかもしれませんが、手順は同じはずです。
安全のため、分解する前にバッテリーを25%以下に放電してください。これにより、修理中に誤ってバッテリーを損傷した場合の発火の危険性を軽減することができます。電池が膨張している場合は、 適切な処理を参照してください。
バッテリーやスクリーンを再組み立てする際には、交換用の接着剤が必要になります。デバイスは正常に機能しますが、IP(Ingress Protection)等級が失われる可能性が高くなります。
必要な工具と部品
油性ペンでオープニングピックの先端から3mmの位置にマークを入れます。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
iPhoneの画面全体に、透明な梱包用テープを重ね合わせます。
次の手順でうまく吸盤が装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにスクリーンを持ち上げてみてください。
この手順で使用する道具:Clampy - Anti-Clamp$24.95
このガイドに従って、付属のテープでスクリーンを固定してください。
青いハンドルをヒンジ側に引くと、リバースクランのアームを解除します。
iPhoneの左/右側の端に向けてアームをスライドします。
吸盤カップをiPhoneの下端付近に装着します。上部に一つ、下部に1つずつ取り付けます。
吸盤カップ両側をしっかりと締め合わせると、標的の場所にしっかりと装着させることができます。
青いハンドルを手前に引くと、アームがロックされます。
ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
吸盤の位置が合っていることを確認してください。装着位置がずれ始めたら、吸盤を少し緩めてアームを装着し直してください。
吸盤ハンドルをスクリーンガラスの端ぎりぎりを避けながら、少し開けた端付近に装着します。
吸盤カップをしっかりと一定の力で引き上げて、ケースとリアガラスの間にわずかな隙間を作ります。
隙間にオープニングピックを差し込みます。
ドライヤーでiPhoneの右端(電源ボタンがある方の端)を90秒、または背面ガラスが少し熱くなって触れない程度まで加熱してください。
リアガラスから吸盤ハンドルを外します。
ゆっくりとiPhoneのディスプレイを右側から(本のページをめくるように)開きます。
作業中、ディスプレイが邪魔にならないよう、ディスプレイを立てかけるための衝立てを準備してください。
スクリーンを立てかけるものが手元にない場合は、吸盤ハンドルを利用するとよいでしょう。
この手順で使用する道具:Magnetic Project Mat$19.95
Y000ドライバーを使って、バッテリーのコネクタカバーを固定している、長さ1.3mmネジを2本外します。
この手順で使用する道具:Tweezers$4.99
スパッジャーの先端で、ソケットからバッテリーケーブルのコネクタをこじ開けて外します。
修理中に誤ってソケットに接触し、デバイスに電源が供給されるのを防ぐため、コネクタをロジックボードから少し離して曲げます。
スパッジャーの鋭利側先端を使って、ソケットから2番目の充電コイルケーブルのコネクタをこじ開けて外します。
ピンセットを使って、Taptic Engineコネクタのブラケットを外します。
ピンセットを使って、メタルブラケットを垂直に折りたたみ、プラスチック製のフックから外します。
メタルブラケットを外します。
プラスドライバーを使って、ラウドスピーカーを固定している次の5本のネジを外します。
長さ1.4 mmプラスネジー3本
長さ1.6 mmプラスネジー1本
長さ1.2 mm Y000ネジー1本
オリジナルのパーツと交換用パーツをよく見比べてください。交換用パーツに付いていない残りのコンポーネントや接着シールなどは、インストールする前に新パーツに移植する必要があります。
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
R2またはe-Stewards認定リサイクル業者(英語)に廃棄物を持ち込んでください。
修理が計画通りに進まなかった場合は、ベーシックなトラブルシューティングを試すか、このデバイスのコミュニティーに質問してみてください。
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
コメント 1 件
The flex cable ground in step #32 tore in my repairs. Any idea the proper name for it so I can maybe find it here or on aliexpress etc?
PLEASE remove back first and disconnect battery before taking cables off!! as per Apple instructions
PC Technology Group - 返信
