メインコンテンツにスキップ
iPad 6 Wi-Fiのホームボタンアセンブリの交換
必要な工具と部品
  1. iPad 6 Wi-Fiのホームボタンアセンブリの交換, iOpenerの使用方法: 手順 1、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, iOpenerの使用方法: 手順 1、 2の画像 2
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
    • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 返信
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 返信
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 返信
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 返信
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 返信
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 返信
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 返信
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 返信
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 返信
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 返信
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 返信
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 返信
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 返信
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 返信
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 返信
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 返信
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 返信
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 返信
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 返信
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 返信
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 返信
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 返信
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 返信
    Can’t you just use a hair curler instead?
    Aspect22 - 返信
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 返信
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 返信
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 返信
  2. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 2、 1の画像 1
    • iOpenerを30秒温めます。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。過熱すると、iOpenerが破裂することがあります。100˚Cを超えるまで加熱しないでください。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 返信
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 返信
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 返信
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 返信
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 返信
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 返信
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 返信
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 返信
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 返信
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 返信
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 返信
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 返信
  3. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 3、 1の画像 1
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 返信
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 返信
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 返信
    This thing melts when placed up side down in the microwave…
    Mark - 返信
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 返信
  4. iPad 6 Wi-Fiのホームボタンアセンブリの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 2
    • 電子レンジがない場合は、熱湯の中にiOpener をいれて温める方法もあります。
    • 鍋を十分な量のお湯で満たして、iOpener を完全に沈めます。
    • お湯を沸かして熱くなったら火を止めます
    • iOpenerを熱湯の中に約2−3分間沈めます。iOpener全体が完全に浸かっているか確認してください。
    • トングなどを浸かって、温まったiOpenerをお湯から取り出します。
    • タオルでiOpener全体を拭き取ります。
    • iOpenerが非常に熱い場合は、先端のタブを持って火傷をしないようにご注意ください。
    • iOpenerの準備は整いました。iOpenerを再度温める必要がある場合は、お湯を沸騰させて、火を止めてからiOpenerを2-3分間浸してください。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 返信
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 返信
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 返信
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 返信
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 返信
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 返信
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. iPad 6 Wi-Fiのホームボタンアセンブリの交換, フロントパネル: 手順 5、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, フロントパネル: 手順 5、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換, フロントパネル: 手順 5、 3の画像 3
    • ディスプレイガラスにひびが入ってしまった場合、割れてしまった部分が広がらないようにガラス表面上にクリアテープを貼るなどして、怪我がないようご注意ください。
    • iPadディスプレイ上にクリアタイプのテープを何重にも貼り、全体を覆います。
    • これはディスプレイをこじ開けて引き上げた際に、ガラスの破片が飛び散るのを防ぐことができます。
    • ここに書かれている手順にできるだけ従ってください。しかしながら、ガラスが一旦割れてしまうと、作業を続けていくにつれてひびが広がってしまう可能性があります。この場合、ガラスを取り出すためにはメタル製工具を使用する必要があります。
    • 目を保護するために保護メガネを装着してください。また液晶ディスプレイスクリーンにダメージを与えないようにご注意ください。
    If you add clear packaging tape, it will create bubbles and the suction cup will become inefficient. To me it was impossible to remove the glass with the suction cup. Since the glass was very cracked, I had to resort to some tweaking with strong tape and pull the this off.
    jfmartin67 - 返信
    If your screen is significantly cracked to the left edge, abandon this entire setup, prepare yourself for a 5-6 hour repair, expect a lot of patience, a lot of cursing and some good old American ingenuity. The suction cup and picks will not work. You have to carefully crack the glass yourself (w/out damaging the panel underneath and carefully pull it apart from the inside to the outside edges. Use a hairdryer to soften the glue under the cracked panel along the edges. Then use an exacto-knife to separate the pieces of the glued panel from the frame body, all the way around the device. Watch out for the home button ribbon connector when using the exacto-knife. There will be glue residue left over, carefully apply some goo-gone to a small area of a paper towel and wipe gently around the frame body to loosen the glue. Then use the plastic spudger tool to scrape off the excess glue.
    The iPad repair is VERY difficult. If you are a working adult, hire a pro. This is not for the faint of heart.
    aaroncope - 返信
    The hairdryer option was way faster and easier than the iOpener. Be VERY careful not to damage the LCD- one small mistake will cost you an extra $100!
    Mike Martin -
    but I’m not American
    Andrew Williams -
    If your digitizer is shattered, the tape will help, but you’re going to need extra picks. Or a razor blade. See below.
    Blair Miller - 返信
    Friendly observation that the image on this step is actually of an older ipad model as the side bezels are far too big. I don't know if that matters to anybody but a noob might see it and think this manual doesn't apply to them. : )
    notalawyer - 返信
    Thank you! Yes things like this matter so much. I successfully replaced an iPhone 6LCD&Screen from the guide. Next was my iPad 2 and the guide said nothing about the power flex cable. They were only stressing about not severing the wifi cable. I followed instructions carefully. Got the screen off and bam. Power flex severed because it was left out of the guide. I saw it in the comments after. I’ll never follow a guide here again without reading the comments. I did receive a discount code for my next purchase but it still caused a lot of inconvience.
    Haley Hodges -
    I had the same experience. My glass was cracked all the way to the left side and the suction cup would not pull the glass up. The packaging tape also didn't help. The heat caused it to lift. I finally abandoned the tape, used a heat gun aimed very carefully at each broken piece of the screen. The picks did work with patience, but I just pulled off each broken part of the glass. I also found that pulling up on one broken part while heating in front of me would let the next piece pull up. I continued heating and breaking all the way around. Do the right side last. Took about 1 hour to get it off, and another hour to clean the old glue off the frame. BTW thanks to this web site and all the comments! No way I would have done this without all the help here! I am now clean and waiting for my new digitizer. I couldn't free the battery (below), so I left it powered up, and verified it till worked before throwing away the old glass. Vince
    Vince Asbridge - 返信
    Taping with package tape doesn't work. You'll need a very large piece of tape if you go this route.
    Travis Dixon - 返信
    Just finished successful repair. I would add this: most folks will be here because of cracked screen. This is not easy; believe the 'complex' rating on this repair. I put tape on my screen because it was badly cracked. This made the suction cup useless, because it just sucked the tape off the scree.n. I used the razor blade technique which worked great, it should be used in the demo, and a good blade should be in the kit.
    dale kingsbury - 返信
    I thought this shouldn’t be too hard - I only had some cracks in the glass, but then at every spot I worked on, the glass turned into nothing but tons of tiny shards. I had to use the points of the tweezers plowing along only the outer edge all the way around, sometimes with a razor blade and often using a hair dryer up close (briefly, over and over). After I got every bit of glass out, I used ordinary rubbing alcohol and Q-tips but I had to rub hard and quickly 100 times on each area to slowly dissolve the glue. I only scratched the LCD once slightly with a tweezer slip. The large chucks of display held together by the packing tape needs something under it to protect the LCD while you are working.
    Robin - 返信
    Using Goo Gone to get rid of the adhesive residue is 20 times faster than using rubbing alcohol, even if it is 91% isopropyl alcohol.
    Skipping the iOpener and using a hair blowdryer, and using Goo Gone in place of the rubbing alcohol are 2 simple changes that will make this job much much easier than the default instructions if the screen is shattered.
    Scott Walker -
    I found the hair dryer is far more effective and less dangerous than using the iopener. If you overheat the iopener you end up pulling a hot plastic bag spewing hot glycerine out of your microwave! Not fun!
    Clifford Sullivan - 返信
    Packing tape won’t do anything. You need to use duct tape to prevent glass shards from spraying everywhere. If your screen is only partially cracked (mine was the top only), modify the directions and focus on the areas that aren’t cracked first. I was able to get the lower 90% of the screen off, and then worked the cracked pieces with a heat gun and metal razor spudger. The entire repair took around 3 hours, and prob 2 hours and 30 min of that was getting the shards out and pieces off. And lots of cursing. I also told my kids if they crack another screen they are out of luck. I am not doing this again.
    Janie Hughes - 返信
  6. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 6、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 6、 2の画像 2
    • 温めたiOpenerをiPadのホームボタンアセンブリの左側サイドに当たるように置きます。
    • iOpenerを約1分間置き、ガラスの下に付けられた接着剤を柔らかくします。
    The iOpener doesn't work because the heat isn't strong enough. I used a hair dryer which proved to be much more efficient.
    jfmartin67 - 返信
    The iOpener didnt work for me either. seems like it gets hot enough but it must not. I spent 30 min with the iOpener, then tried a hair dryer.
    kinchma - 返信
    “At least a minute.” Bullshit. Get the iOpener good and hot, place it on the area you’re going to work on clear side down, and cover it with a towel. Walk away for 2 minutes. Make yourself a drink — you’ll need steady hands later.
    Blair Miller - 返信
    I've done this with an iOpener and at least in my case, it worked fine. You may have to modify the heating instructions though, since not all microwaves are created equal.
    Jeff Suovanen - 返信
    ii i just did this and it took a while but i figured it out it is true this thing doesnt get hot enough BUT heat it 2 times and then the 3rd time when u place it on the ipad put the ipad box on top and then maybe a second ipad on top of the box so it kinda smashes i down but not too much for it to break and then wait for it to turn warm THEN use the succion THEN the gap appears. the glue is super strong on the ipads so yea it will take some time lol
    Joel Tyson - 返信
    Doesn't work. Perhaps include more copy on exactly how to do it?
    Travis Dixon - 返信
    The iOpener does not work. It simply it is not hard enough to soften the glue. The heat hair dryer method does not work either.
    Javier Lozada - 返信
    The goal is simply to weaken the glue enough that you can use your suction cup to open up a tiny gap under the glass, so you can insert an opening pick and slice through the adhesive. It doesn't actually take all that much heat; the picks will do most of the work once you get them in there. iOpeners, hair dryers, heat guns all work fine in my experience—the iOpener is just a bit more foolproof because it won't get hot enough to cook the display panel underneath.
    Jeff Suovanen - 返信
    I used iron..surprise!! yeah pretty fast tho…put a layer of fabric (towel in my case) ontop, along the edge of screen and start ironing..
    carvelera - 返信
    If using a hair dryer or heat gun make sure it is not too high heat. My heat gun has two settings, one 750 degree and an 1100. After using it on high I discolored the digitizer and warped the LCD slightly (only shows on pure white backgrounds). Low worked for the rest of the repair just fine. Also using a razor blade or something besides the pick works nice for the initial pry. Once you have a gap big enough, insert the pic and you’re all set.
    Robert - 返信
    I don’t have an iOpener, my heat gun wasn’t handy. The last time I did something like this it was a 90-100 degree day, so I just put it out in the sun for a while, and it worked great. This time it’s fall, so I used a 420W halogen Light that I have for photography. (A standard heat lamp would probably work too, but might take longer.) I held it close to the light until it felt hot to the touch, just a couple minutes, then I left is sitting about 16” below the light for 5-10 minutes to sink in and warm uniformly. It worked great.
    For me, steps 8-31 were basically one step "Carefully pry off the digitizer glass with the plastic tools" took all of 30 seconds.
    Seth Childers - 返信
    Although very hard this does work. The first time opening the ipad after buying it 8+ years ago it took about 3 times of heating the iopener. It did require an amount of pressure I did not expect but it did come open as instructed. I did add a towel and apply pressure to the iopener to make sure the heat transferred.
    hmcarbajal - 返信
    The iOpener didn’t work for me at all, zero, it literally did nothing. I resorted to my heat gun on low and yeah you need to be super careful, but once I started the adhesive came off pretty easy.
    David Yutzy - 返信
    I used a 2-level heat gun, too. Supposedly 707 degrees/923 degrees.
    I kept the heat gun about 1” away from the glass and used only the low setting. Even so, I did alter the digitizer pretty quickly in a few locations around the edge. It still functions fine, and you only see it under certain circumstances, so not a huge deal. But irritating. Be cautious about too much heat. It just looks like sort of a faint, polarized grid.
    Don’t be afraid to put tension on the glue and just hold it. If it is warm enough, the glue will relax under sustained tension. This isn’t a speed event. Don’t try to rush it, or you’ll break something.
    Now that those infrared surface thermometers have become so inexpensive, it would be great if someone posted a target temperature for softening the glue without damage. That would take some of the guesswork out of this process.
    Tim - 返信
    If you heat the iOpener somewhat longer than they recommend, and get it about as hot as your hand can stand, then place it on the iPad and cover with a towel for at least 3 minutes. Then really be patient. I got a bit impatient, and took a chance and slipped a really fine “exacto-type” of blade vertically beside the suction cup as I lifted, and thankfully that worked. That made enough room to get one of the “guitar pick” wedges in. The rest went fine.
    Pete - 返信
    I used the iOpener to soften the adhesive. I was extra careful and it took me about 90 minutes to get to Step 30. With my acquired experience I would say, it may be done in about 30 minutes. Most important: Be patient! You may have to reheat the iOpener a few times until you will be able to do Step 9. Once I had this part done, it was a lot easier. So I would say the first 60 minutes I spent on steps 1 through 9.
    marcelflueeler - 返信
    I’ve been using a heat and isopropyl alcohol combo on iPhone screens with no problem. This specifically says “only” heat. I feel like she’s trying to tell me to keep a lid on my IA. Because I don’t know what other methods some rogue might be trying in their efforts to compromise adhesive.
    Audi Archer - 返信
  7. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 7、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 7、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 7、 3の画像 3
    • iPadは外側から見るとしっかりとした作りに見えますが、フロントガラスの下には壊れやすいコンポーネントが存在しています。これらにダメージを与えないためには、各手順で指定されたエリア以外は温めたりこじ開けたりしないでください。
    • この手順を進んでいく中で、次のエリアはこじ開けたり、接触しないように特にご注意ください。
    • 正面カメラ
    • アンテナ
    • ディスプレイケーブル
    Don't assume anything!! I thought I was pulling on the screen connector and I was pulling on an antenna component instead. Didn't ruin its connection range but I sure remember doing it and now my iPad has a little internal flaw only I'm aware of.
    Travis Dixon - 返信
    Correct me if I’m wrong but the LTE version apparently has 2 antennas on each side of the front-facing camera and it’s not shown on this post to avoid prying. I just scratched one of them following these instructions.
    Pacman - 返信
    A note about the multiple image thumbnails - roll your mouse over them to get an animated effect, rather than clicking on them individually
    Rusty - 返信
    Audi Archer - 返信
  8. iPad 6 Wi-Fiのホームボタンアセンブリの交換, リバースクランプの使用方法: 手順 8、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, リバースクランプの使用方法: 手順 8、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換, リバースクランプの使用方法: 手順 8、 3の画像 3
    この手順で使用する道具:
    Anti-Clamp
    $24.95
    購入する
    • 次の2つの手順では、デバイスの開講作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルを後方に引き、リバースクランプのアームのロックを解除します。
    • 青いハンドルをヒンジ側に引くと、オープニングモードが解除されます。
    • 吸盤を左端の中央付近に配置し、上下に1つずつ装着します。
    • リバースクランプの下部をしっかりと固定し、上部カップをしっかりと押し下げて吸盤を装着ます。
    • iPadの表面が滑りやすく、リバースクランプがしっかりと装着できない場合は、梱包用テープで表面を覆ってから、強いグリップを作ることができます。
  9. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 9、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 9、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 9、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤の位置が合っていることを確認してください。装着位置がずれ始めたら、吸盤を少し緩めてアームを装着し直してください。
  10. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 10、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 10、 2の画像 2
    • 青いハンドルをヒンジから離して前方に向かって押し、オープニングモードにします。
    • 画面が十分に熱くなっていない場合は、ドライヤーを使ってiPadの左端に沿って熱を加えることができます。
    • ヘアードライヤーの詳しい使い方は、こちらのガイドをご覧ください。
    • 接着剤がはがれて、底面が開くまでそのまま1分ほど同じ状態を保ちます。
    • リバースクランプで十分な隙間ができたところで、スクリーンのフレームの下にオープニングピックを挿入します。
    • リバースクランプで十分な隙間ができない場合は、その部分にさらに熱を加えて、ハンドルを時計回りに半回転させてください。
    • 一度に半回転以上回さず、1分ほど待ってからさらに半回転、回します。時間をかけてリバースクランプを回していきます。
    • 次の2つの手順はスキップしてください。
  11. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 11、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 11、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 11、 3の画像 3
    • 温めた側の真ん中から少し上辺りに、吸盤カップを取り付けます。
    • しっかりと吸盤がスクリーンに装着されるにはカップがスクリーン上に完全に平らに付いているか確認してください。
    • iPadを片手で押さえながら、背面ケースをフロントパネルのガラスから離すために吸盤カップを上部に向けて引っ張りあげます。
    • iPadのスクリーンの破損がひどい場合は、透明なパッキングテープで表面を覆うと、吸盤がうまく接着します。 または、強力なテープ(ダクトテープなど)を使用して、ハンドルに折りたたんでください。
    In this picture above, the glass isn't cracked at all so it helps the suction cup to be effective as it is hermetic. With cracked display, it won't work.
    jfmartin67 - 返信
    Suction cup would not work for me. No amount of heating with iOpener or hair dryer would allow even the slightest gap to form. I ended up looking at some YouTube videos and used a razor blade. I put the razor blade perpendicular to the top glass, right at the edge of the glass and pushed down until the blade went down 1/4". Then heated some more and pried up the glass enough to put in an opening pick. I spent a lot of time working with the suction cup. Glue was just too strong.
    kinchma - 返信
    It's funny that iFixit changed the image they used. Even they themselves realized how stupid it was to try a suction cup on taped up surface. C'mon guys! You should at least make foot notes for your readers and let them know what to do if the glass is already shattered. It's a slow methodical process that involves working with a iOpener type tool. I personally have one that looks like a prison shank (lol)
    Scott S - 返信
    Not sure what you are referring to there—I see no evidence in the document history of the photos having been changed. Suction cup + packing tape can work, but it depends how badly the glass is broken and the quality of the tape. Sometimes it takes a couple attempts. You can also skip the suction cup and try using tape alone to pull on the panel, if your tape is sticky enough. There are no guarantees though, which is why we have the disclaimer right in Step 4 that the procedure can be pretty fussy if you're working with a shattered panel. Depending on where it's broken and how badly, you're going to have to improvise.
    Jeff Suovanen -
    Jeff, the change is evident from image 4, where all the surface is taped up. In this picture you show a clean not broken surface and yes, the suction cup works...
    Simone Gabbriellini -
    Ah, I see what you're saying! I can understand why you guys would assume that, but in reality the entire guide was originally photographed using an intact panel. We later added a step showing how to protect yourself if you have a shattered panel (with photos to go along with, obviously). I'm afraid it wouldn't be practical to re-shoot the entire guide every time we make a small change like that.
    Jeff Suovanen -
    The suction cup is useless if your glass is shattered. Use a new, sharp razor blade, and insert it vertically between the edge of the glass and the metal back of the iPad. Don’t worry about pressing too hard — there’s a lip that stops the blade from going in too far and damaging anything. You’ll probably have to do this several times, but eventually the blade will “bite” into the edge of the glass well enough for you to pry it up. Insert a pick underneath the razor, then remove the razor and continue as directed.
    Blair Miller - 返信
    After having to read several comments on this screen removal and the clear packing tape, I too have to agree that the tape method does not work well at all if your screen is already shattered. I combined several methods, with lots of patience to remove the screen on my iPad Air 2. What I found it very helpful was the heat gun used for paint removal. The heat gun generates a lot of concentrated heat at lower air velocity, unlike generic hair dryer, so you must be very careful not to ruin the electronics, and risk burning your hands and anything around it. My heat gun that I purchased from Home Depot had a nozzle to direct and focus the heat on a small area. That was helpful in working small area at a time. This method work thoroughly well.
    Taiji Saotome - 返信
    It would work if you leave iopener in microwave for 1 minute.
    Don’t trust the instruction from ifixit.
    you can put iopener in microwave for 1 minute without any harm.
    Note. you have to make sure that it is in cold position before you put it into microwave.
    phongsiri nirachornkul - 返信
    Suction cup didn’t work for me either, went the razor blade route (using an exacto knife blade) with very minimal damage to the aluminum shell. Be warned, if your screen has cracked along the edge (as it almost 100% certainly has if you’re reading this guide), the screen will continue to shatter and splinter as you make your way around the edge. That’s when having the screen taped up well will be to your advantage. There’s also a good chance you’ll have to re-insert the razor blade on the other side of a fracture and start the lifting process again, but keep going, being sure to avoid the points called out in this guide and you should be fine.
    Also, do not apply the suction cup to an area of the screen with cracks and no tape. If you’re near the edge you run the risk of brutally shattering that area of the glass if the glass gives before the suction cup.
    Micah Sledge - 返信
    In order to get this to work for me I had to heat the IOpener to over 104 C - I needed to get the screen over 40 C before the adhesive would loosen.
    Also I had to put the ipad on a towel - the granite countertop it was on was sucking the heat out too fast.
    Jack Williams - 返信
    This step was brutal on my nerves - read about too many people ruining their iOpener and I don’t have a heat gun. I had to keep heating the iOpener incrementally hoping I wouldn’t pop it. … but if you’re patient, persistent, and cautious, you can definitely tell when you’re seeing separation. The iOpener ended up being WAY hotter than 30 seconds was getting me - borderline scorching my hands.
    William Thompson - 返信
    Could not loosen the adhesive using the iOpener. Had to use hair dryer.
    Erwin yi - 返信
    As the others noted, the suction cup is useless on a cracked screen, especially if you’ve applied tape (like the instructions say you should). The screen I was working on was busted up pretty bad, I ended up removing it and then going back to remove the edge glass and adhesive. When you have a really busted screen just take your time and use a heat gun or good hot hair dryer and it will eventually come off.
    I used an iSesame tool vs a razor to pry the edge (from a previous replacement project) but again, the iOpener and suction cup are useless.
    David Yutzy - 返信
    Thank you for the comments above. I was using the iOpener unsuccessfully, then turned to the hair dryer and heated it up for over 3 minutes. This gave me the gap I needed to insert the opening pick and begin the process. So, with patience and a hair dryer, I was able to get the digitizer off.
    0812mgr - 返信
    You really need a lot of patience here (30-45min). But then it works. The best way was with this plastic "crowbar" to get the beginning. You really have to press hard to get in between.
    Arne Meier - 返信
    The suction cup provided in the toolkit didn't work on anything. Tape helped, but I eventually went in through a small cracked shard to create an entry point at the bezel
    Tom Weber - 返信
    I've passed on the iOpener as suggested in these comments and have tried to use a hairdryer. heating on high at medium speed for 1 minute then trying the suction cup. heating for another minute then using the suction cup. Been doing this for 1/2 an hour but it isn't working. Need to take a break because I'm afraid I'm going to hurt in internal components of the iPad 6 (just trying to replace a dead battery) Any suggestions ???
    Just a guy - 返信
    LOL...i tried the pastic clear tape to hold the cracked glass then apply the hairdryer. It melted the plastic tape glue and thus making the handle with the duct tape useless and the duct tape just pulled the melted glue from the plastic packing tape up like butter. But the screen still not budging. I've tried the hair dryer for 5 mins and nothing. I've tried the iOpener and that's useless. I'm heating it up 30 secs a time. I tried 1 min. The screen is welded shut.
    brian -
  12. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 12、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 12、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 12、 3の画像 3
    • 吸盤カップによって引き上げられた際に出来る隙間に開口ピックを差し込みます。
    • 開口ピックをディスプレイ横にある黒い外縁よりも深く差し込まないでください。このピックを深くまで差し込んでしまうと液晶ディスプレイを傷つけてしまうことがあります。
    • 吸盤カップのプラスチック部分の持ち手を引っ張り、吸盤力を緩めてディスプレイアセンブリから外します。
    I found it much easier to use a single edge razor blade instead of the pick. After getting that inserted, it was easy to slip the pick between the blade and the case. Disclaimer - Razor blades are very sharp and you could easily hurt yourself or your iPad if you use one.
    donprius - 返信
    This is an amazing tip! After trying for 10 minutes to use the pick with no luck, I grabbed a small razor blade and that worked perfectly to get me started!! Thanks!!
    Ashley Garner - 返信
    The suction cup also didn’t work to create a gap - it cracked the screen when i tried to lift (the screen was already cracked). This was after rotating between the iOpener and a microwavable hot pack for food. The iOpener was around 175 degrees, it brought the surface of the iPad to 130. I was finally able to lift the glass using a razor blade and then the picks like donprius. I continued to use the iOpener to loosen the glue around the rest of the iPad but I think a heat gun would have been more efficient.
    Marc Ducret - 返信
    You have to heat the glue really much, or you will, as i did, crack the glass.
    Linus Grüne - 返信
    Best bet is to mark the pick with a sharpie line on how far your maximum limit is so you don’t damage the LCD.
    Jon Snyder - 返信
    The iOpener works well, be patient and keep reheating until you can see the screen start to give a little. I kept putting mine in the microwave and it worked faster when the iOpener was hotter. 40 second intervals did the trick for me eventually
    Jackson Taylor - 返信
    I spent an hour trying to lift the screen of an iPad Air first gen. The trick I found was that its a combination of lifting the screen a millimetre and then wiggling a razor blade vertically in the slot between the screen and the metal frame (yes its a microscopic slot). I used a hair drier on a section of the edge of the middle of the screen as above. The middle area allows for a bit of flexibility in the rail - we’re talking 0.5mm which is just enough for the razor.
    So hit a section of the screen edge with the drier till its hot to touch, do the suction cap thing as above, insert the blade vertically and wiggle it *ever so slightly* in the slot as you don’t want to break anything. Keep repeating this until you see even the slightest rise in the screen under the cap. At this point, remove the razor and insert the blue pick. It should easily dig in and under the screen, but no further than the black border.
    Remember, small wiggly steps will avoid breaking anything. Better a number of small heat and wiggles than a lift and snap.
    Rusty - 返信
    for those who need to open more than one iPad, the iflex is safer and more effective than a razor blade. i use it to get started then switch to a pick
    iFlex Opening Tool
    Stow - 返信
    Yea, this suction cup cracked my glass. This made it near impossible to slide the picks around. I may try again another day, but I suspect it’s toast at this point.
    Jason Prothero - 返信
    I should have noted the difficulty rating before thinking I could replace the battery myself. I could have saved myself the cost of replacing a cracked screen, which happened when I attempted this step. I did not want to overheat the iOpener but consequently, I could not get a pick inserted underneath the screen. (I think the glue must take a lot more heat than expected to melt.) So just a warning to more novice tinkerers—this repair wasn't the same as fiddling with screwdrivers and a million small parts.
    mlliu - 返信
  13. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 13、 1の画像 1
    • iOpenerを再び温めて、同じ箇所に置きます。
    • 修理作業中、 iOpenerを温めすぎないようにご注意ください。 iOpenerを再度温める際は、少なくとも前の作業から10分ほど待ってから行ってください。
    This says "Always wait at least two minutes before reheating the iOpener", however the iOpener itself has a warning printed upon it that says wait at least 10 minutes. And that 10 minutes warning is also mentioned in Step 2 above.
    Scott - 返信
    Sorry about that! We fixed the text on this step. The two-minute interval was for an older version of the iOpener—the text printed on your iOpener will have the correct interval, which is indeed ten minutes. It can burst if overheated or reheated too quickly.
    Jeff Suovanen -
    It still says 2 Minutes up there in the warning
    Sandro Krumbein - 返信
  14. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 14、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 14、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 14、 3の画像 3
    • 2番目の開口ピックを1番目に差し込んだ開封ピック付近に挿入し、iPadの端に沿って接着剤を剥がしながら下側に動かします。
    You guys really need to show how it's done when your iPad isn't perfect like the one pictured above.. C'mon..
    Scott S - 返信
    This is for BATTERY REPLACEMENT not CRACKED SCREEN REPLACEMENT!!
    Corey Barcus -
    How do you slide the picks when the glass is broken? Even with the glass taped, it pulls away from the tape rather than the housing. I've just further shattered the glass with my attempts.
    chrisweiler - 返信
    With my shattered screen, I was able to remove it using the suction cup slightly and a metal pry, had to break the edge glass some for removal also but it didn’t do damage. More layers of shipping tape helped to make the screen stay together better and come off more intact.
    Jackson Taylor - 返信
  15. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 15、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 15、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 15、 3の画像 3
    • 続けて接着剤を剥がしながら、開口ピックディスプレイの横から下に向かって動かしていきます。
    • 開口ピックが接着剤に絡まり動かなくなった場合は、ピックをiPadの横に沿って"回転させながら"接着剤を剥がしていきます。
    This gives a false illusion to the difficulty of these repairs when you guys make guides using perfect devices. What about devices with dinged corners? A reader is gonna slap on a new screen and shatter it the second they apply pressure thinking it will fit into a dented corner lol
    Scott S - 返信
  16. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 16、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 16、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 16、 3の画像 3
    • 1番最初に差し込んだピックを手に取り、iPadの上部端に向かってスライドして動かします。
    • フロントガラスを通して開口ピックの先端が見えたら、びっくりしないでください。ーピックを少しだけ外側へ引いてください。ほとんどの場合は問題ありませんが、奥まで差し込みすぎないように注意してください。液晶ディスプレイ上に接着剤が付いてしまった場合、取り除くのが難しいためです。
    I managed to get a couple of fingerprints on the LCD.
    What's the best way to clean 'em off?
    What's the safest way?
    Mike McIntosh - 返信
    What I’ve read, and seems to work, is gentle circular pressure with a very clean, dry microfiber cloth. Lacking that, use a TINY drop of water ON THE CLOTH, not on the LCD. Small amounts of alcohol can be used, in my experience, but only if the above don’t work, and with better results if used in small amounts and applied to the cloth, not the LCD.
    Bonnie Baxter - 返信
    Can confirm. Microfiber with a little isopropyl worked great to clean off any adhesive or fingerprints from mine. Thanks for the tip.
    Robert -
    If you dare to use alcohol on your device, at least use isopropyl alcohol, not ethanol!!!
    Pierre-Aurélien - 返信
  17. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 17、 1の画像 1
    • iOpenerを再び温め、iPadの上部端、正面カメラの上に置きます。
    • 修理作業中、iOpenerを温めすぎないようにご注意ください。前の作業から少なくとも10分間置いて温めてください。
    • 形を自由に変化できるiOpenerをお持ちの場合は、上部左端と上部先端を同時に温めるよう曲げてください。
  18. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 18、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 18、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 18、 3の画像 3
    • 開口ピックをiPadの左端上部にスライドさせて接着剤を剥がします。
    I broke the screen glass of my ipad just right when I moved the guitar pick towards the upperleft corner of the screen as depicted in your instructions. (Whereas my ipad screen was in perfect condition : no scratches, not broken at all...). There must be something wrong here. Be advised: move the pick towards the corner with caution !!!
  19. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 19、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 19、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 19、 3の画像 3
    • 開口ピックをiPadの上部端に沿ってスライドさせます。カメラの手前で止めます。
    • 3番目の画像はフロントカメラがiPadのどの位置に内蔵されているかを示したものです。
    • 開口ピックを正面カメラ上にスライドしないでください。レンズ上に接着剤を伸ばしてしまうとカメラにダメージを与えてしまいます。次の手順は正面カメラを傷つけないで作業を進めるためのアドバイスを記しています。
  20. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 20、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 20、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 20、 3の画像 3
    • ピックを少し外側に向かって引き出し、上部端に残っているわずかな先端を正面カメラ上部に沿って動かします。
    At this point I’d use paper tape on the margins of the screen to mask off areas where you should use caution with the pick. Its just a visual reminder not to run the picker too deep in these areas. They are: the camera lens, lower right hand side and where the two antenna are along the base. Step 6 third image highlights these areas.
    Rusty - 返信
  21. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 21、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 21、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 21、 3の画像 3
    • 正面カメラを過ぎた位置でiPadの中に開口ピックの先端を残して作業を止めます。
    • 2番目のピックを取り出して、正面カメラの左側に差し込みます。それからiPadの左端に向かって接着剤を剥がしながらスライドします。
  22. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 22、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 22、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 22、 3の画像 3
    • 先ほどの(1番目の)ピックをiPadの奥まで差し込み、正面カメラの右側から角に向かってスライドします。
  23. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 23、 1の画像 1
    • iPadの角に3本のピックを残したまま、正面パネルの接着剤が再び付着するのを防ぎます。
    • iOpenerを再度温め、iPadの残りのサイド端にーボリュームボタンとロックボタンに沿って、これを置きます。
  24. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 24、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 24、 2の画像 2
    • iPadの上部右端周辺に開口ピックをスライドさせて接着剤を剥がします。
    • このピックを接着剤が再び付着しないよう残し、新しいピックを次の手順で使用します。
  25. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 25、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 25、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 25、 3の画像 3
    • 新しい開口ピックを差し込み、これをiPadの右端の真ん中までスライドさせます。動かしながら接着剤を剥がします。
    • iPadの下部からディスプレイケーブルが装着されています。ここでiPadの下から4.5インチあたりの位置で作業を止めます。
    Why there’s such an obsession with not damaging the cables is beyond me. Be careful, so as not to damage what the cables are connected to. But the cables are part of the replacement digitizer, so if you nick or even slice through them (like I did with the one closest to the bottom) don’t worry about it.
    Blair Miller - 返信
    Keep in mind that some people are here to open an intact display to replace internal components! In those cases, keeping the cables un-harmed is quite important ;)
    Sam Goldheart -
    My digitizer WAS ok and I was only replacing the battery I wasn't careful enough when coming around the side with the pics and got a hold of the cable just enough with the pic to pull it off the underside of the panel. The battery replacement went great other than now I have to replace the digitizer. :(
    BE CAREFUL WITH THIS STEP!!!
    Dylan Bouterse - 返信
    And if you are replacing the digitizer, you have to reuse the fingerprint sensor home button. I sliced through mine and now I’ll not have fingerprint sensor. Each home button is matched to the main board and if switched out you will loose that sensor ability.
    David - 返信
    Like others, I damaged my digitizer cable while doing a battery replacement. It would be a good idea to use some blue tape to mark the spots to avoid during the glue slicing procedure.
    donprius - 返信
    I also damaaged the digitizer cable while doing a battery replacement. Use just the tip of the opening pick.
    Dean Gross - 返信
    People need to realize iFixit routinely duplicates instructions for more than one type of repair/replacement. However, all of the comments are combined, which leads to confusion.
    laura moon - 返信
  26. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 26、 1の画像 1
    • 開口ピックを挟んだままで、iOpener を再び温めてiPadのホームボタン端の上に置きます。
  27. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 27、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 27、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 27、 3の画像 3
    • 左側中央に差し込んでいる開口ピックを左側下部の角に向かって、接着剤を剥がしながらスライドしていきます。
    • 左側下部の角でピックを残したまま止めます。これ以上こじ開けないでください。iPadにピックを挟んだままにします。
    • 3番目の画像はiPadの下部分に装着されている2本のアンテナとホームボタンの様子です。
    • 次の手順ではこれらのコンポーネントにダメージを与えないために、どこからこじ開ければよいのかを教示しています。iOpenerを温めて、指定された場所をこじ開けてください。
  28. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 28、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 28、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 28、 3の画像 3
    • 接着剤が再付着しないように、開口ピックを左側下部の角に挟んだままにします。
    • 新しいピックを手に取り、左側アンテナの上をゆっくりと滑らせます。ホームボタン手前で止めます。
    • iPadの中央に向けて、外側のエッジのみをピックでスライドさせます。中央から外側に向かってピックを戻さないでください。この方向に動かすとアンテナにダメージを与えてしまうことがあります。
    • 開口ピックを2回以上スライドする必要がある場合は、左端外側から中央に向かってピックを再挿入して、作業を継続してください。
    • 次の手順に移る前に、ピックを中央付近で挟んだままにします。
  29. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 29、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 29、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 29、 3の画像 3
    • 再び新しい開口ピックを手に取り、前回の手順で止めたピックの右側に差し込みます。
    • ホームボタンと右側のアンテナ上をスライドさせます。接着剤を剥がすため、ピックの先端のみを使って動かします。
  30. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 30、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 30、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 30、 3の画像 3
    • 接着力が弱くなるため、開口ピックを右側下部の端に挿入します。左側に開口ピックをスライドして、ホームボタンの手前で止めます。
    • 左側のアンテナと同様に、外側の端から中央に向かってスライドします。中央から外側に向けて動かすと、アンテナを傷つけてしまうことがあります。
    This step needs a BIG CAVEAT to not insert the pick far enough to damage the home button/touch ID cable, as it is DIRECTLY above where you’re directing people to insert the pick. I just ruined a ribbon cable by following this guide too closely.
    tabormeister - 返信
    Sadly only after damaging my home button flex cable, I read your comment. There should be a big warning here as it is very easy to tear this cable.
    Bouke - 返信
    I also damaged the home button cable. Check the placement of the cables in steps 37-44.
    Paul Klein - 返信
  31. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 31、 1の画像 1
    • iOpenerを再び温めて、iPadの音量コントロール側の端に沿って配置します。
  32. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 32、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 32、 2の画像 2
    • この手順では特に慎重に作業を進めてください。時間をかけてゆっくりと、接着剤が温かく柔らかくなっているか確認します。開封ピックを使って接着剤全体を剥がします。必要に応じて、作業を止めて iOpenerを再び温めることも考慮してください。
    • 音量コントロールの反対側の両角にはピックを挟んだままにします。ガラスを持ち上げるように、ピックを少しひねります。ディスプレイケーブルの端に沿って留められた接着剤が剥がれます。
    • かなりの接着力が残っている場合は、ピックをそのままの場所に残して iOpenerを再び温め、問題の箇所に当てます。
    You will end up having to scrape the outter ledge to remove the old screen. I bled and got glass shards everywhere. Good luck!
    Travis Dixon - 返信
    That won't happen if you use gloves and protective glasses!
    tanner85 - 返信
  33. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 33、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 33、 2の画像 2
    • ディスプレイケーブルの端に沿って、接着剤をゆっくりと剥がしながら、ディスプレイを上げていきます。
    This is very tricky if the screen is cracked (which I would assume most people are replacing the screen because of a crack). Use duct tape to try and secure the shards as much as possible, but be prepared for shards flying everywhere. Search for videos on cracked screen removal, there’s a good ifixit one. Maybe they can link it here? I finally was able to get it all by using a heat gun and metal spudger/razor like the guy in the video.
    Janie Hughes - 返信
  34. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 34、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 34、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 34、 3の画像 3
    • フロントパネルのガラスを固定したままで、開口ピックを使って最後の接着剤を切り離します。
    • ディスプレイケーブルにダメージを与えたり、切断しないように作業は十分注意しながら行ってください。
    Detailed pictures that better indicate the difference between the remaining adhesive and the two mylar cables (the very cables you are trying to avoid damaging!) would be much appreciated. On my unit the two were VERY hard to distinguish.
    dlcatftwin - 返信
    This step does not need to be performed here. I cut this adhesive once I had removed the lcd and display cables. This makes it much easier to avoid damaging anything. Just prop the glass up on something while you perform steps 31 - 42, then cut remaining adhesive and remove.
    Robert - 返信
    The front camera has a black bezel cover but it is attached to the broken glass digitizer. Peel it off and save it. I plan to tack glue it to the camera instead of gluing it back to the new digitizer glass. It has two alignment bumps so maybe it doesn’t need gluing to either side but I found it on the ground when it came off of the the broken digitizer. I almost tossed it as part of the broken glass.
    Robin - 返信
  35. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 35、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 35、 2の画像 2
    • 全ての接着剤が外れたら、本を開く状態のようにガラスパネルを開いて作業台上で休めましょう。
    • 再装着の間は、ケースに残っている接着剤の残りをガラスクリーナなどイソプロピルアルコールで綺麗に拭き取ってください。(そしてフロントガラスを再利用する際はこれも綺麗に拭き取ります)プレカットされた接着ストリップディスプレイ用接着剤の装着方法を参照して、接着剤を交換します。
    • 再組み立て時に、フロントガラスとiPadのフレームの間にフレックスケーブルを挟み込むのは簡単です。 フレックスケーブルに注意し、ゆっくりと折りたたんでフレームの下に押し込みます。 フレックスケーブルの折り目が平らになる程度に押さえ込まれると、修理が不可能になる程度、損傷してしまう可能性があります。
    my replacement digitizer has rigid flex with adhesive tape where the connectors extend. how does this “fold” back inside the frame?
    David - 返信
    Same here. I removed the adhesive tape, but now what?
    Dvi -
    It looks like I have the same or similar question: the “hinge” part of the digitizer cables (the flap portion) looks like it is supposed to tuck into the crevice between the LCD panel and the side of the aluminum body - my replacement (from iFixit) has sticky contact on the upper side of this flap, making me think that its supposed to adhere to the side of the LCD panel, but the instructions do not make this clear - is my assumption correct?
    dlcatftwin - 返信
    Or, does the flap adhere to the underside of the front panel’s right edge?
    dlcatftwin - 返信
    I attempted to put this protrusion underneath the LCD, and it kept coming up above the LCD. As there were no instructions, I put it as best as I could underneath the LCD as I cannot imagine that it folds up against itself?
    Dvi - 返信
    I tried to put it ‘inside’ the case but was not able to - at the end, I just glued it against the front glass.
    I must have done something wrong with the new home-button assembly as the fingerprint sensor does not work anymore - However, I am not going to go through that repair again so passcode it is.
    Michael Berneis - 返信
    My screen from ifixit had the rigid flaps with adhesive also. I removed adhesive and adhered it to the new glass, it worked fine and solved the problem with the flaps not pushing down.
    Jackson Taylor - 返信
    if there is adhesive glue on the inside of the digitizer and the top of the LCD what do you recommend to clean it.
    scprillwitz - 返信
    Isopropyl alcohol (and certainly not ethanol!!!)
    Pierre-Aurélien -
    Don’t throw away your old screen until you take the home button off of it! My screen was shattered and I kind of have a phobia of broken glass, so I bundled it all up and threw it into the trash can immediately. Next day when I went to continue the job I was sad that my roommate had finally taken out the trash for once and my home button was halfway to the dump by then.
    Sparky - 返信
    Cleaning with isopropyl alcohol is not really working well. I am using it with a qtip. Is there a certain way you recommend in order to actually the adhesive off?
    Brooke Parkhouse - 返信
    Yes, the flap seemed to want to be attached to the glass, not go down the slot. All went together well, except that my home button doesn’t work. I suspect the connections wasn’t right, although I did my best to (gently but firmly) push it in. Too late to do anything about it now.
    Mussollini - 返信
    I got my repair kit yesterday, had a go at it today on my iPad Air 1 (A1474). I’ve opened up phones before (the kind that open up easily), but first time dealing with a glued-together device. Anyway I got there, and now I’m putting things back together. I have a question regarding the pre-cut adhesive to hold the glass back on. Is it meant to be applied to the glass, or the frame?
    SHL - 返信
    Ok never mind - I just looked at the digitizer for this iPad and saw that the adhesive is preapplied to the glass, which confirms my suspicions. Now I can proceed and bring this repair to a conclusion.
    SHL -
    And it’s done! Doing the battery calibration now, but I’m relieved that the battery is working. I did turn on the iPad prior to removing the blue strips on the adhesive to make sure it was working before committing to fix the glass in place.
    To reiterate the point, the adhesive strips go on the glass. The way they are packaged with the clear plastic makes it go very smoothly.
    There are 2 oversize pieces of plastic sandwiching the adhesive sections. These keep the strips in their original shape free of dust off until you are ready to use them. Once you remove these, there is another clear plastic strip which has an inside edge that matches the adhesive section’s inside edge. This plastic allows you to position the adhesive accurately on the glass while keeping your fingers away from it. This is especially important on the right side where the digitizer cables are. Once you remove this clear plastic, there is still the blue film with pull tabs. You can leave these on to do a power up test, then remove them. …cont
    SHL -
    … After doing the power on check, you can also check that all the buttons work, home button, camera, speakers etc. Then I turned it off (probably wasn’t necessary), removed the blue strips and pressed the glass in. For this last step I suggest lining up the left edge of the glass with its corresponding edge in the aluminum shell, and then gently pressing down on the right side. ALSO: while doing this last step, look carefully at the right side for the ribbon cables there. In my case (reusing original digitizer), they were protruding just a smidge, so I used the spudger to just nudge it a bit and they got into place, and then I pressed the right side down. I then pressed down all around the edges of the glass.
    SHL -
    quick question... if this is a replacement, why are we worrying about the digitizer cables? My glass is shattered pretty bad on the to the left of the home button where he says to work. So I can't apply suction cup there. I don't understand the need to be concerned about the cables if the digitizer is going to be trashed...
    Michael M - 返信
    I'd like to add when at this stage and you notice some of the old black adhesive may be hanging off the digitizer DO NOT remove any of it. Wait until you have to thing fully removed. It's way too easy to tear one of the cables if you try removing it now.
    Lindsey W - 返信
  36. iPad 6 Wi-Fiのホームボタンアセンブリの交換, LCD: 手順 36、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, LCD: 手順 36、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換, LCD: 手順 36、 3の画像 3
    • LCDに留めてあるネジを隠しているテープを剥がします。
  37. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 37、 1の画像 1
    • LCDを固定している4.3mm #00プラスネジを4本外します。
    Both of the iPad 6th gen models i have seen so for (note they were cellular also) had the LCD secured with a grey silicone kind of adhesive in each corner under the screws. So you can’t just lift the LCD as you normally would after removing screws, it would break. I found you could pick at the corner closest to the rear camera easiest, slightly lift that corner and gently separate the other side next to the headphone jack. Then while supporting the LCD , lever the other end free with a up-and-down motion making slight progress each time.
    Anvil Electronics - 返信
    I found the same thing on my 32GB wifi only ipad. Was unable to lift the screen off once I’d removed the screws so followed the instructions above and gently prized the screen up from the top left-hand screw bracket and it came away. Then moved onto the top right hand one.
    mann134 - 返信
    One YouTube video said to dig all that glue out. I didn’t and it seems to not hurt to leave it there but you do have to break free from it.
    Robin - 返信
    On my iPad 6, there were small rubber tabs covering the two screws on the front camera side. I carefully held them out of place with tweezers while unscrewing the screws.
    Martin Winter - 返信
  38. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 38、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 38、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 38、 3の画像 3
    • LCDを完全に取り外さないでください。まだホームボタンの端にいくつかのケーブルとiPad本体が接続されています。 前面カメラ側からのみ持ち上げます。
    • スパッジャーの平面側先端を使って、LCDを指で掴みやすいように、凹みからLCDをこじ開けます。 ネジ穴の周りに接着剤が付けられている場合は、ナイフで切開する必要があります。
    • 本のページのようにiPadのLCDを裏返して、カメラの近くで持ち上げ、リアケースのホームボタンの端に向けます。
    • ディスプレイを裏返す時はLCDケーブルに注意してください。
    • LCDを正面側に向けて、ディスプレイケーブルにアクセスできるようにします。
    • LCDを柔らかく、清潔で糸くずの出ない布の表面に置きます。
    When you replace the LCD be sure to make sure it is screwed in fully. It is easy not, especially on the cornet where the digitizer cables are. The LCD is very sensitive and if you bend it then it can stop working. I was just pressing the digitized in place at the end of a repair and the screen was covered in white lines.
    hugh - 返信
    I have no idea of what the logic board looks like !!!
    HenryFMora - 返信
  39. iPad 6 Wi-Fiのホームボタンアセンブリの交換, バッテリーコネクタ情報: 手順 39、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, バッテリーコネクタ情報: 手順 39、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換, バッテリーコネクタ情報: 手順 39、 3の画像 3
    • これらの画像は、ロジックボードの下にあるバッテリーコネクタの外観を示したものです。画像を参考にしながら、安全にバッテリーを取り外してください。
    • バッテリーコネクタは、ロジックボード上にある片持ちバネがバッテリーのコンタクトパッドに押し付けられていることに注意してください。ロジックボードとバッテリーの両方が接着されているので、バッテリーを外すには、何か薄くて柔軟なものを接点間に滑らせる必要があります。
  40. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 40、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 40、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 40、 3の画像 3
    • バッテリーコネクタをロジックボードに固定している2.3mm #000プラスネジを1本外します。
    • ショートのリスクを減らすため、バッテリーの接続を外す際には、バッテリー絶縁ピックを使用できます。
    • バッテリーブロッカーをロジックボードのバッテリーコネクターの下に35度の角度でスライドさせます。
    • バッテリーブロッカーを無理な力でコネクタの下に押し込まないでください。バッテリーブロッカーをロジックボードの下にはめ込むのが難しい場合は、代わりに トランプ を使ってバッテリーを取り外してみてください。
    • バッテリーブロッカーやトランプは、ロジックボードの下を何の障害もなくスライドすることが理想的です。15度の角度で止めてください。
    • バッテリーブロッカーをその場所に残したまま、作業を行ってください。
    If you insert a regular pick without a gap then you can damage this connector and will need a new motherboard. If in doubt just insert into the left corner enough to raise it a tiny bit. Arguably, if you are not sure, then it is safer just power off and don’t power back on until everything is fully connected. A photo of how this connector looks with its cover off would really help for people that have not seen this type of battery connector before. You just need to get it to lift a tiny bit, Do not try to slide anything under the contacts….
    hugh - 返信
    I bumped this darn thing several times, it was twisted and skewed making me freak out but the iPad still works. I am thinking you should pull it out and put the screw back in right after the LCD is removed. Then use it again just before putting the LCD screen back in. The pick is sticking out there waitng to be be bumped.
    Robin - 返信
    Hi Robin,
    Unfortunately, there is no easy way to pull the battery connector out of the logic board. If you try to pry this connector off, you will irreparably damage it. The easiest solution is to insert the battery blocker in-between to cut the power.
    Arthur Shi -
    The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board.
    So what is the new method?
    Wil Thieme - 返信
    This is my question as well. Seems like this phrase contradicts the instructions. Confusing. Any reply?
    Melissa Hoffman -
    We are currently working on a better isolation procedure! In the meantime, I’ve updated the warning to hopefully clarify the issue.
    Arthur Shi -
    Why do you need to “To reduce the risk of a short”? There does not seem to by any risk of a “short” in this process. I can see other reasons for disconnecting the battery. I am an electrical engineer so I would appreciate a professional grade answer to this question.
    Rumboogy - 返信
    I’ll give it a shot!
    When you remove the screw, it doesn’t disconnect the battery, as the connector uses spring contacts to touch the battery pads.
    If you leave the battery connected, it leaves the logic board energized. As there are many exposed traces and SMT components on the logic board, there is a chance that you accidentally bridge a trace with a metal tool, resulting damage. In addition, the display connector contains tiny pins, and the pinout is such that if you pry the connector from an energized logic board, there is a chance that a voltage rail pin may accidentally touch something it shouldn’t, blowing out the backlight circuitry.
    Arthur Shi -
    My battery was dead when i did the repair. Did not really need to perform this step
    Igor Kapitanker - 返信
    Take a waterproof playing card, cut out the shape of the battery blocker and slide that under. Battery blocked and pins not at risk of damage. Got that from a YouTube video made by a microsolder repair tech fixing the damage caused by jamming a blocker in between the contacts.
    Melody Fraysier - 返信
    Thanks for the tip Melody! I’ve updated the instructions to include the playing card method.
    Arthur Shi -
    I could not for the life of me get the playing card in there, but my iPad was turned off, so I decided to ‘risk’ a short, instead of potentially damaging the battery connectors by jamming the card in there as hard as possible. My repair went fine, no short, however I realized AFTER closing everything up that I forgot to put the battery screw back in. Really hoping this doesn’t become an issue long term, because I don’t want to pry this brand new screen off just to put the battery in.
    Janie Hughes - 返信
    Let us know! I wasn't able to use the screw again after removing the battery blocker. Now my iPad turns off and on every so many minutes and when it restarts it's 1% and then shows actual charge.
    Martin Hinojosa -
    When you come to screw this back together, do not overestimate how little force it takes to strip the thread on this #000 screw. I did, and I now I can't screw this back down and have the problem where the iPad restarts every 3 mins 20 sec after you turn it on due to a poor connection here. I've used card to pack this out so the LCD puts a little clamping force on the terminal once you screw it back in, but it's not really enough so the iPad still suddenly restarts occasionally.
    Rory Condon - 返信
    I use a small screwdriver and pry underneath that brown bracket from the top edge by the camera (with the elongated metal cover removed of course) all the way before the battery, then lift up just enough for me to unhinged the battery out of the secure post. I don't know why Apple has to go through ALL THIS just to connect the battery since there is a small screw AND ADHESIVE securing it anyway. Nonetheless the whole job (replacing the lcd screen and battery was a major pain in the neck!
    80s Guy - 返信
  41. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 41、 1の画像 1
    • ディスプレイケーブルブラケットから1.4mm #000プラスネジを3本外します。
    I believe these are also Phillips #00, not Phillips #000.
    Kevin Chatterton II - 返信
    I lost a 1.4mm screw where can I buy these small screws and how big are they? 1.4mm x? flared or flat head
    ferdinando.gregis@gmail.com - 返信
    Is this part important? It seems like I lost it.
    Will - 返信
    You don't have to remove any of this when replacing the battery but doing so will make the job easier and can prevent from accidentally knocking the adjacent cables.
    80s Guy - 返信
  42. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 42、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 42、 2の画像 2
    • スパッジャーの平面側先端を使って、ロジックボードからディスプレイケーブルブラケットをまっすぐ慎重に持ち上げます。
    • ディスプレイケーブルコネクタは、ブラケットの下側で接続されていますので、スパッジャーをブラケットの下奥深くまで押し込まないでください。コネクタにダメージを与える恐れがあります。
  43. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 43、 1の画像 1
    • LCDを取り外します。
  44. iPad 6 Wi-Fiのホームボタンアセンブリの交換, フロントパネルアセンブリ: 手順 44、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, フロントパネルアセンブリ: 手順 44、 2の画像 2
    • ホームボタンリボンケーブルコネクタを覆っているテープを剥がします。
  45. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 45、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 45、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 45、 3の画像 3
    • スパッジャーの平面側先端を使って、ホームボタンリボンケーブルのZIFコネクタ上のタブを跳ね上げます。
    • ZIFコネクタからホームボタンリボンケーブルをまっすぐ注意深く引き抜きます。
    I'm confused about the home flex cable connector required for the 6th generation iPad. It was my understanding that this model required an 18 pin connector. But these excellent pictures clearly show a 14 pin connector, just like the one for the first generation iPad Air AKA the iPad 5. I know this is not the primary focus of this guide, but can anyone clarify this for me?
    Bonnie Baxter - 返信
    I did the whole repair but this part is the problem HELP !!! I unlocked it but it took me 1 hour to carefully pull out the HOME BUTTON RIBBON CABLE. It finally came out with tweezers but now I CAN'T GET IT BACK IN and as a result my touch I.D. won't activate. It seems there was a tiny bit of black tape overlapping the connector on the ribbon which I carefully cut off exposing only the connector on the ribbon itself but how the heck does it slide in before you lock it. It seems easy on Youtube videos but mine just doesn't slide in with hand or with tweezers. OR in fact is there another connector that controls the TOUCH I.D. ???
    Just a guy - 返信
    Failed this step- broke the connector. If I try this again, I'd be inclined try to remove the home button from the front panel without unplugging it. Everything else seems to work fine.
    Sandy Kilday - 返信
  46. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 46、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 46、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 46、 3の画像 3
    • スパッジャーの平面側先端や指の爪を使って、ソケットから2つのデジタイザーケーブルコネクタを注意深くまっすぐ持ち上げます。
    • iPadにダメージを与えないようにするため、ロジックボード上のソケットではなく、コネクタのみを持ち上げてください。
    • 再組み立ての際は、コネクタがソケットに完全に装着しているか確認してください。ディスプレイに問題が発生することがあります。
    Where can I get a good used motherboard for a A1954 iPad 6 gen everywhere I look, there sold out ?...
    Trent Weaver - 返信
  47. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 47、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 47、 2の画像 2
    • リアケースに留められた接着剤からホームボタンリボンケーブルを注意深くめくり上げます。
    If you can make sure to not pull on the home button side, i would leave out this step. i replaced two displays so far, on the first i removed it, but left it connected on the second attempt. worked like a charm
    Tommy Wienert - 返信
  48. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 48、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 48、 2の画像 2
    この手順で使用する道具:
    Polyimide Tape
    $9.99
    購入する
    • フロントパネルアセンブリを取り出します。
    • 新しいディスプレイで"ghost"もしくは "phantom"のタッチ入力の問題が発生した場合、パネル背面のハイライト表示されたエリアに、カプトン(ポリイミド)テープなど非常に薄い絶縁テープを塗布することで解決できます。 iFixitの修理用パネルには適切な断熱材が施されているため、テープを追加する必要はありません。
    • 絶縁がないと、デジタイザのこれらの領域が他のコンポーネントに対して接地し、タッチ入力の誤動作を引き起こす可能性があります。
    • 断熱材は肉眼では見えず、多くのiPadに使用されている発泡ダストバリアストリップとは異なります。
  49. iPad 6 Wi-Fiのホームボタンアセンブリの交換, ホームボタンアセンブリ: 手順 49、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換, ホームボタンアセンブリ: 手順 49、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換, ホームボタンアセンブリ: 手順 49、 3の画像 3
    • フロントパネルの裏面からホームボタンケーブルを慎重に剥がします。
    • ケーブルのメタル製シールドにアクセスできるまで剥がしてください。
    START using extreme caution at this point. This ribbon IS VERY FRAGILE, especially after the silver rectangle/shield. That gold piece is attached to the cable.
    Jennifer Altamirano - 返信
  50. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 50、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 50、 2の画像 2
    • メタルシールドとフロントパネルの間に開口ピックを差し込み、デジタイザーから慎重に持ち上げます。
    I lifted the metal shield from the outside edge so not to tear the ribbon cable. I think I even used the razor blade (the tool of last resort).
    Robin - 返信
  51. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 51、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 51、 2の画像 2
    • ホームボタンブラケットからメタル製コンタクトを慎重に剥がします。
    I ripped the ribbon cable out of the button at this step… be extremely gentle!
    James - 返信
    So what exactly does this metal contact do? Can the HB work without that single gold contact?
    Perrin Aybara - 返信
    Can anyone answer this question? The gold metal rectangle contact ripped off even horizontally with the rest of the home button cable. Do I need to order a whole new home button with cable? Or will I at least get functionality from the home button, only missing that little gold rectangle ?
    PC Ops -
    I ripped mine. Reattached the metal contact to the cable with some tape as best as I could. The button and touch ID work, so not sure if the metal contact is absolutely needed…? If it’s just for grounding?
    Joshua Schoemmell -
    Thank you for showing the bracket up close!
    Dvi - 返信
    EXTREME CAUTION!!! The little metal contact is very fragile. I ripped mine off. Well, when I say ripped I mean I breathed on it.
    I would suggest maybe warming that part up before pulling and don’t just pull up from the main ribbon. Work it slowly.
    David Raines - 返信
    CAUTION!!! that little gold contact got me too!! Please update the instructions to include this.
    Did you find out if the home button still works without the rectangular gold contact?
    PC Ops -
    I wish I didn’t peel this last piece off, I don’t think you need to. It seems to be what keeps the bracket lined up over the button. Now I have to try to glue it back on perfectly so the bracket is centered over the home button.
    Robin - 返信
  52. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 52、 3の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 52、 3の画像 2 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 52、 3の画像 3
    • プラスチックの開口ツールを使って、フロントパネルの裏側からホームボタンブラケットを外します。
    • ホームボタンブラケットを再装着する際は、両面テープもしくは接着剤を使って、ブラケットを固定してください。
    • ホームボタンブラケッとの片側が外れたら、しっかりとブラケットを掴んで、フロントパネルから剥がします。
    I'd recommend using something stronger than double sided tape. I completed this whole repair without too much lasting trouble, but the biggest issue was I didn’t get the home bracket secured firmly enough. A few weeks after the repair, the home button got pressed in and lodged under the hole cut for it, so I can’t unlock my iPad at all (the home button can’t be “pressed” in its current state). So I’m ordering a second screen and have to go through everything again. This time I’m using super glue to get that thing welded on there. If anything breaks in the future, I’m just getting a new iPad.
    Micah Sledge - 返信
    I had this problem too. Very frustrating. Not sure what I’d do to fix this. If you are repairing this for someone else, then super glue would not be the best option.
    MYMS! - 返信
    I don’t see why iFixit does not simply sell an optional iPad screen with a new home button pre-installed - other competing companies do it, and with iFixit’s pro reputation, having a pre-installed option would certainly be an excellent sales option. My 2¢ worth.
    dlcatftwin - 返信
    The home button that came with your iPad is the only one that will allow touchID to function. This is why this must be migrated from the old to the new screen. Of course, if your iPad does not have touchID, this is not a concern.
    Robert -
    TIP FOR HOME BUTTON REMOVAL
    I found it to be simpler by using the same pry tool shown in the image and pry the tab furthest from the flex cable. Its an easy start knowing that if you damage the cable you can loose Touch ID permanently.
    My steps were basically as follows in this specific order:
    1. Using a guitar pick, release the cable from the adhesive and SLOWLY lift up the cable and the components with it
    2. Once you reach the tabs that hold the home button in place, pry the tab furthest from the flex cable (this requires a little more force)
    3. Once the tab furthest from the home button is lifted away, you can hold on to the metal piece (The whole tab) and lift it away safely.
    4. Using your finger, press in the home button to release it from the glass and your done.
    Narayan Ramcharitar - 返信
    After replacement m home button works fine, but it’s very loose in the housing. I can tip it around by moving my fingers to the edges. Any ideas what I did wrong?
    Mike van Grunsven - 返信
    I had to use far more pressure to remove the bracket than I was comfortable with and when it came loose it went flying. Re-attaching is easy, but I used some hobby glue to secure it in place, so if the screen breaks again, that part is NOT coming off again. I’m guessing because I did this I don’t have the “depressed” issues that others have described, it seems to be like new at this point.
    David Yutzy - 返信
    I agree, the bracket needs glueing when refitting. Replaced the glass on my iPad and after a couple of days the home button came loose and stopped working. Now i just broke the glass when opening the iPad to fix the home button bracket. I love my life! :-)
    Mats Fredholm - 返信
    I used a piece of the rectangular section of an adhesive strip cut to the exact size of the home button bracket feet to reattach it to the digitizer for reassembly. It is very strong and worked better than double sided tape or glue.
    agree. I did same. Also do not forget to remove protective film from the inner side of the new digitizer. Do it before you start reassembly.
    Igor Kapitanker -
  53. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 53、 2の画像 1 iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 53、 2の画像 2
    • デジタイザーの外側からホームボタンを押し出して、固定している接着剤から乖離します。
    • プレッシャーをゆっくりと与えていきます。切断しやすいデリケートなガスケットに接着剤が付いています。
    Are these last several steps necessary in just replacing the front glass panel that is cracked? my ipad is a wi-fi only
    Joe Hall - 返信
    Yes, even if you’re only replacing the front glass panel, you still have to transfer your original home button from the old panel to the replacement. Even if the new panel comes with a new home button, Touch ID will only work with the original home button.
    Adam O'Camb -
    Buy an extra home button adhesive gasket. The adhesive from the original will not be reusable
    John Marx - 返信
    I second this advice. I skipped it the first time, and the home button was too wiggly (although it worked). Now that I’ve replaced the screen a 2nd time (ugh), this time adding a new gasket, it’s a bit more firm, but still more wiggly than originally. If you don’t mind the button being lose, you probably can reuse the gasket, but if I have to do this again, I’ll probably get another gasket.
    Gary Wolfe -
    Yep, tore mine even as delicate as could be. I would highly recommend hitting the home button with a heat gun prior to attempting to remove. On the plus side, the replacement gaskets are cheap and easy enough to replace.
    Notice the sharp crease in the ribbon cable near the home button? I thought I bent it at some point but it was already there.
    Robin - 返信
    My screen was damaged in such a way that removing the old gasket didn't tell me how to install the new one.
    Sandy Kilday - 返信
    I completed the reassembly of my digitizer. the process was pretty simple. After reviewing all the feedback and issues mentioned by others, I made sure to properly attach the home button/touch ID to my new screen by carefully installing it and ensuring the gasket was firmly in place. I used a small amount of liquid glue to secure the bracket as well. While everything is working correctly, I did notice that my repair kit came with a new bracket and home button gasket (with adhesive on the parts I used glue- I assume) lol. I clearly didn't utilize that… do you think I’ll be okay? I just hope I won't need to redo the whole process again just for the home button. 🤦🏻‍♀️ I don’t know how I missed that little baggie…
    Zaine A - 返信
  54. iPad 6 Wi-Fiのホームボタンアセンブリの交換: 手順 54、 1の画像 1
    • ホームボタンアセンブリを取り外します。
    Be very careful !!!!
    Easy Repair - 返信
    I did a screen replacement and it’s impossible to place the home button bracket in the correct position, now the home button doesn’t click anymore. Works, but you have to press harder.
    fjaroski - 返信
    Given the delicacy of this stage, I believe it behooves iFixit to offer a panel replacement option with a new Home button pre-installed.
    Others do; with iFixit’s reputation, such a purchase option would be a welcome, stellar addition to its inventory. Yes, you would have to cancel your Touch-ID setting prior to repair, but that’s a small inconvenience to having to negotiate such a procedure. My 2¢ worth.
    Thanks, iFixit, for the excellent instructions
    dlcatftwin - 返信
    I second this - tore the home button cable during disassembly and ordered another home button assembly just to figure out that I need the gasket and holder as well as it was not included. -
    Michael Berneis -
    Yes - the metal contact on the home button tore… now I have to figure out how to do another repair. Also, my replacement screen comes with plastic on both sides and multiple tabs in different colors. Now I’m too scared to remove those for fear of ripping something.. you should have glass replace directions here too.
    Anu Anand - 返信
    Hi sir
    Iam try replace ditigizer on iPad 6th gen
    Will my home button and finger print if I replace the home to another the home button will if I buy it from you guys
    John Clark - 返信
    replaced the display with new home button assembly, new gasket, and holder - button works but fingerprint sensor not anymore - It would be great to have detailed instructions for the complete the home button assembly with all the different parts, not only the teardown for reference. - i.e. it seems you need to push the button through the gasket before assembly so the cable leaves inside and the order is glass-button-gasket-holder.
    The article explicitly states that the Home Button and the Motherboard are a BONDED PAIR. If you replace one without the other, Touch ID will stop working. This is why the instruction say you have to retain the button.
    Matt Spriggs - 返信
    While I’m a fairly tech savvy person, telling people to reverse the steps is ridiculous—you need to show people what to expect. Second, include the home button on the new screen sale. I’m in the middle of the repair at this point, I’ve given you $100 and this seriously frustrating, especially when the home button you sell (which I had to buy after the screen, because I inadvertently tore off a bit) DOESN”T include the proper adhesive. PS—trying to get the adhesive on the new button is a practice in torture.
    Now the adhesive ring in on the old glass and rips apart if you pull it off. I think you don’t need the adhesive ring but it keeps the button splash proof. I am going to use tiny amounts of glue but all the more reason to buy a new assy just for that ring.
    Robin - 返信
    I had to notch out the glass adhesive just slightly where bottom right corner of the home button bracket sits against it. It is curved and needed to be squared off to match the bracket. I held the ribbon cable, button and bracket in place with tape before I glued the bracket. I also used a flashlight behind the bracket and button gap to see that the bump on the bracket was lined up with the button’s switch.
    Robin - 返信
    I'm quite disappointed the fact that this is a replacement guide but does not include re-assembly steps.
    We ordered a new home button and gasket for an iPad 5, which works with the iPad 6 home button as well.
    Neither guide has re-assembly instructions for the home button.
    My customer service is important and I would like to see better guides that include disassembly and reassembly steps.
    I need to know how to properly apply a home button gasket to the home button.
    If I am missing something, please let me know.
    PS. It's not good practice to use metal tools so close to the main board. An insolated pair would be more ideal.
    Will Helbing - 返信
    The small black dot on the home button microswitch comes off no matter how careful you are. Home button will not work properly if you loose the black dot. I have done 5-6 repairs and on 4 of them the black dot just fell off. I have been successful using a small piece of Kapton tape and reinstalling the black dot in the center of the home button microswitch.
    tomgeorge - 返信
    I also removed a metal ring that sits between the gasket and the glass. It has the same shape of the gasket, and it’s glued to the glass after removing the home button assembly. Used a thin double-sided tape with strong glue when reassembling; maybe B7000 glue would be easier.
    Andre Saito - 返信
    It's so frustrating seeing these guides that just say “follow these steps in the reverse order" when I'm really searching for a technique and guidance on replacing the rubber gasket and and proper placement of the bracket so it clicks as it should and doesn't sink in.
    Calan Belvin - 返信
    Agree with previous comments. Would be helpful to go over replacing the button gasket, and the actual reassembly instead of just ‘reverse order’.
    Janie Hughes - 返信
    it would be nice to see how to re assemble when to pull backing off glue, how to add grommet, how to bend new wires in place to seat correctly
    Thomas Frank - 返信
    Would I be able to use the new replacement home button as to go back to home page? Or is it just going to he for the decoration?
    shanparshan - 返信
    I needed 6 hours for
    1) removing the cracked display glass with a scalpell,
    2) to remove the glue with glue remover,
    3) to install a new home button (because I cutted the homebutten flex-cable) and
    4) to glue the touchdisplay (digitizer) with T7000 diplay glue!!!. The delivered glueband on the digitizer shouldn't be used, because it is to weak.
    There is a HowTo missing to install a new home button. I also didn't found a new homebutton from iFixit. So I had to buy it somewere else.
    MAISY MOUSE - 返信
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
30 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Evan Noronha
メンバー登録日: 02/05/15
223,466 ポイント
168のガイドは作成済み
5 件のコメント
This guide can be a little subtle when compared to actually doing the home button repair. Here are some troubleshooting tips from what I've learned about doing these:
First, when removing the home button itself, I do NOT recommend pushing the button up through the screen as shown here unless you're certain it will adhere properly to the gasket on the new/ same screen. Alternatively, after you have removed the bracket holding it in place, heat the display around the home button and slide a pick and gently remove the paper gasket WITH the home button still attached, then move the entirely assembly. Go slow and use about a minute of 85c heat on a plate / get it hot enough that the adhesive gives, just under where it tolerable to touch but no more.
If you have moved the button and bracket but can't get it to click, first check the alignment. There is a small metal nub on the bracket's underside; this needs to meet the part of the button that actually “clicks" when you press it, otherwise the button will not work…
crtrue - 返信
(cont)
The bracket does NOT sit dead center over the home button but is sightly higher than it. You may need to place it a few times before you get it settled correctly.
The bracket adhesive can lose stickiness, especially if you move it multiple times; in this case you will have to either replace it or add some glue. This is important as if the bracket fails in any way, your home button will fall into the device or at the very least become unusable. A little dab of Jewelers glue on each bracket side followed by about ten minutes under compression can keep it on without raising it too much with red tape (which can make it sit too high and make it unusable if not heated to cure correctly). Also although tempting, once you have applied new adhesive, leave the button alone for awhile to allow it to cure; do not try and “test" it while still wet as you'll push the bracket loose and have to redo the whole affair.
crtrue -
How does the gasket attach? This whole thing ive actually gotten lucky. I didnt know these things are this strong.
Shellby Haddock -
Yes very touchy so far. Now im waiting for parts .
Shellby Haddock - 返信
When reattaching the home button bracket, I’ve found it works well to clean the old adhesive from the bracket, then apply a small amount of Goop (soft cure adhesive) to each tab, then use binder clips (paper clips for multiple sheets) to hold the two bracket tabs firmly in place while the glue sets over several hours. By using the binder clips, you can jockey the bracket around to perfectly align the actuator tip over the home button clicker before glue sets.
jamespoe - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 92
過去 30 日: 410
今までの合計 41,144
