メインコンテンツにスキップ
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Matthew Hook
Matthew Hook とその他 5 人の作成者
最終更新日: May 7, 2024
25分
中レベル
This guide will walk you through step by step on how to replace the screen display assembly on a Toshiba Satellite CL15t-b1204x. The screen display is vulnerable to any type of physical damage, whether that be from exposure to liquids or screen crackings. It may also need to be replaced if it stops working after a long period of time. One thing to keep in mind, is that the display comes as a full assembly, and a new assembly can be ordered online.
必要な工具と部品
ツール
もっと見る
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 2、 1の画像 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 3、 1の画像 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 4、 1の画像 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 5、 1の画像 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 6、 1の画像 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: 手順 7、 3の画像 1 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: 手順 7、 3の画像 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: 手順 7、 3の画像 3
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 8、 3の画像 1 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 8、 3の画像 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 9、 2の画像 1 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 9、 2の画像 2
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 10、 1の画像 1
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 11、 3の画像 1 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 11、 3の画像 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: 手順 11、 3の画像 3
    • Open the laptop and remove the display assembly from the keyboard assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Matthew Hook
メンバー登録日: 03/25/19
439 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019人のメンバー
IUPUI-HOVDE-F19S1G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 309
