メインコンテンツにスキップ
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
zeena qiryaqoz
zeena qiryaqoz とその他 3 人の作成者
最終更新日: December 15, 2022
10分
簡単
高画質の画像が必要
This guide will show you how to replace the keyboard on your Toshiba Satellite C55Dt-A5306.
必要な工具と部品
ツール
  • Spudger
    Spudger
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 手順 3、 2の画像 1 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 手順 3、 2の画像 2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 4、 2の画像 1 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 4、 2の画像 2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 5、 1の画像 1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 6、 2の画像 1 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 6、 2の画像 2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 7、 1の画像 1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 8、 1の画像 1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 9、 2の画像 1 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 手順 9、 2の画像 2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
終わりに
作成者
3人の作成者と共同で作成されました。
zeena qiryaqoz
メンバー登録日: 01/17/17
301 ポイント
3のガイドは作成済み
チーム
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Oakland University, Team 2-3, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G3
4 メンバー
14のガイドは作成済み
コメント 1 件
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 747
