メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SteelSeries Nimbus+ Controller Battery Replacement
必要な工具と部品
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 手順 1、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 手順 1、 2の画像 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    FixBotに聞いてみる
    コメントを追加
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: 手順 2、 1の画像 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    FixBotに聞いてみる
    コメントを追加
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: 手順 3、 1の画像 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    FixBotに聞いてみる
    コメントを追加
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 手順 4、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 手順 4、 2の画像 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    FixBotに聞いてみる
    コメントを追加
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 手順 5、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 手順 5、 2の画像 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    FixBotに聞いてみる
    コメントを追加
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 手順 6、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 手順 6、 2の画像 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    FixBotに聞いてみる
    コメントを追加
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 手順 7、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 手順 7、 2の画像 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    FixBotに聞いてみる
    コメントを追加
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 手順 8、 3の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 手順 8、 3の画像 2 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 手順 8、 3の画像 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    FixBotに聞いてみる
    コメントを追加
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 手順 9、 3の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 手順 9、 3の画像 2 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    FixBotに聞いてみる
    コメントを追加
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: 手順 10、 1の画像 1
    • Remove the back cover assembly.
    FixBotに聞いてみる
    コメントを追加
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 手順 11、 2の画像 1 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 手順 11、 2の画像 2
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    FixBotに聞いてみる
    コメントを追加
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: 手順 12、 1の画像 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
    FixBotに聞いてみる
    コメントを追加
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
Adriana Zwink
メンバー登録日: 12/18/19
67,401 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
26,572のガイドは作成済み
1件のガイドコメント
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 55
今までの合計 2,300
