メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Steam Controller (2nd Gen, 2026) Main Board Replacement
必要な工具と部品
  1. Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: 手順 1、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: 手順 1、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: 手順 1、 3の画像 3
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBotに聞いてみる
    コメントを追加
  2. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover screws: 手順 2、 2の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover screws: 手順 2、 2の画像 2
    この手順で使用する道具:
    TR6 Torx Security Screwdriver
    $5.99
    FixBotに聞いてみる
    コメントを追加
  3. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover: 手順 3、 2の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Remove the back cover.
    FixBotに聞いてみる
    コメントを追加
  4. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: 手順 4、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: 手順 4、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: 手順 4、 3の画像 3
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBotに聞いてみる
    コメントを追加
  5. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 2
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBotに聞いてみる
    コメントを追加
  6. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket: 手順 6、 2の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket: 手順 6、 2の画像 2
    FixBotに聞いてみる
    コメントを追加
  7. Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 3
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    FixBotに聞いてみる
    コメントを追加
  8. Steam Controller (2nd Gen, 2026) Main Board Replacement: 手順 8、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement: 手順 8、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement: 手順 8、 3の画像 3
    • Repeat to disconnect the other rumble motor.
    FixBotに聞いてみる
    コメントを追加
  9. Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 3
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    FixBotに聞いてみる
    コメントを追加
  10. Steam Controller (2nd Gen, 2026) Main Board Replacement: 手順 10、 2の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement: 手順 10、 2の画像 2
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    FixBotに聞いてみる
    コメントを追加
  11. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: 手順 11、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: 手順 11、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: 手順 11、 3の画像 3
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    FixBotに聞いてみる
    コメントを追加
  12. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: 手順 12、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: 手順 12、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: 手順 12、 3の画像 3
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    FixBotに聞いてみる
    コメントを追加
  13. Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: 手順 13、 3の画像 1 Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: 手順 13、 3の画像 2 Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: 手順 13、 3の画像 3
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
Spencer Day
メンバー登録日: 09/14/22
195,262 ポイント
1,243のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 151
過去 30 日: 900
今までの合計 3,242
