メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Steam Controller (2nd Gen, 2026) Right Trigger Replacement
必要な工具と部品
  1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 手順 1、 3の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 手順 1、 3の画像 2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 手順 1、 3の画像 3
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBotに聞いてみる
    コメントを追加
  2. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 手順 2、 2の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 手順 2、 2の画像 2
    この手順で使用する道具:
    TR6 Torx Security Screwdriver
    $5.99
    FixBotに聞いてみる
    コメントを追加
  3. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 手順 3、 2の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Remove the back cover.
    FixBotに聞いてみる
    コメントを追加
  4. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 手順 4、 3の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 手順 4、 3の画像 2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 手順 4、 3の画像 3
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBotに聞いてみる
    コメントを追加
  5. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 2
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBotに聞いてみる
    コメントを追加
  6. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 手順 6、 2の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 手順 6、 2の画像 2
    FixBotに聞いてみる
    コメントを追加
  7. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 手順 7、 3の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 手順 7、 3の画像 2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 手順 7、 3の画像 3
    • The right trigger will be on your left-hand side since the controller is laying upside down.
    • With one hand, fully depress the right trigger.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
    FixBotに聞いてみる
    コメントを追加
  8. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 手順 8、 3の画像 1 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 手順 8、 3の画像 2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 手順 8、 3の画像 3
    • Remove the right trigger.
    • The spring will likely stick to the trigger's magnet.
    • If the spring stayed on its post, leave it in place.
    • During reassembly, make sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
Spencer Day
メンバー登録日: 09/14/22
195,262 ポイント
1,243のガイドは作成済み
1件のガイドコメント
What are the lengths and diameters of the springs? Making them stiffer is what I want to do as they do feel a bit too soft.
Deividas “IHickUp” Misevicius - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 64
過去 30 日: 403
今までの合計 994
