メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Steam Controller (2nd Gen, 2026) FSC Board Replacement
必要な工具と部品
  1. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Before you begin: 手順 1、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Before you begin: 手順 1、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Before you begin: 手順 1、 3の画像 3
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBotに聞いてみる
    コメントを追加
  2. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the back cover screws: 手順 2、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the back cover screws: 手順 2、 2の画像 2
    この手順で使用する道具:
    TR6 Torx Security Screwdriver
    $5.99
    FixBotに聞いてみる
    コメントを追加
  3. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the back cover: 手順 3、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Remove the back cover.
    FixBotに聞いてみる
    コメントを追加
  4. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the battery: 手順 4、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the battery: 手順 4、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the battery: 手順 4、 3の画像 3
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBotに聞いてみる
    コメントを追加
  5. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the mounting bracket screws: 手順 5、 2の画像 2
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBotに聞いてみる
    コメントを追加
  6. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the mounting bracket: 手順 6、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the mounting bracket: 手順 6、 2の画像 2
    FixBotに聞いてみる
    コメントを追加
  7. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the rumble motors: 手順 7、 3の画像 3
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    FixBotに聞いてみる
    コメントを追加
  8. Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 8、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 8、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 8、 3の画像 3
    • Repeat to disconnect the other rumble motor.
    FixBotに聞いてみる
    コメントを追加
  9. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the interconnect cable: 手順 9、 3の画像 3
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    FixBotに聞いてみる
    コメントを追加
  10. Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 10、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 10、 2の画像 2
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    FixBotに聞いてみる
    コメントを追加
  11. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board screws: 手順 11、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board screws: 手順 11、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board screws: 手順 11、 3の画像 3
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    FixBotに聞いてみる
    コメントを追加
  12. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board: 手順 12、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board: 手順 12、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the main board: 手順 12、 3の画像 3
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    FixBotに聞いてみる
    コメントを追加
  13. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Rubber piece information: 手順 13、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Rubber piece information: 手順 13、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Rubber piece information: 手順 13、 3の画像 3
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    FixBotに聞いてみる
    コメントを追加
  14. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the hinge pin: 手順 14、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the hinge pin: 手順 14、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the hinge pin: 手順 14、 3の画像 3
    • With one hand, fully depress one trigger.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
    FixBotに聞いてみる
    コメントを追加
  15. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the trigger: 手順 15、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the trigger: 手順 15、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the trigger: 手順 15、 3の画像 3
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
    FixBotに聞いてみる
    コメントを追加
  16. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the other trigger: 手順 16、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the other trigger: 手順 16、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the other trigger: 手順 16、 3の画像 3
    • Repeat to remove the other trigger.
    FixBotに聞いてみる
    コメントを追加
  17. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Reassembly information: 手順 17、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Reassembly information: 手順 17、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Reassembly information: 手順 17、 3の画像 3
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
    FixBotに聞いてみる
    コメントを追加
  18. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the midframe screws: 手順 18、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the midframe screws: 手順 18、 2の画像 2
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to slip and damage the flexible button circuit.
    FixBotに聞いてみる
    コメントを追加
  19. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the midframe: 手順 19、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the midframe: 手順 19、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the midframe: 手順 19、 3の画像 3
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone membranes are now sitting loose in their recesses. Don't flip the front shell or the buttons will fall out. Optionally, remove the membranes and buttons and set them aside.
    • During reassembly:
    • If you removed the buttons and their membranes:
    • Make sure the rubber button dampeners (that surround the button recesses) are pushed down and fully seated against the shell.
    • Install the buttons and membranes, using the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
    • Check the two large silicone button membranes to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
    FixBotに聞いてみる
    コメントを追加
  20. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Check for the Steam button membrane: 手順 20、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Check for the Steam button membrane: 手順 20、 2の画像 2
    • Check if the Steam button's silicone membrane stuck to the button circuit on the midframe.
    • If it did, either put the membrane back in place or set it aside.
    FixBotに聞いてみる
    コメントを追加
  21. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the trackpad cables: 手順 21、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Disconnect the trackpad cables: 手順 21、 2の画像 2
    • Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
    FixBotに聞いてみる
    コメントを追加
  22. Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 22、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 22、 2の画像 2
    FixBotに聞いてみる
    コメントを追加
  23. Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 23、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 23、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement: 手順 23、 3の画像 3
    • Repeat to disconnect the other trackpad cable.
    FixBotに聞いてみる
    コメントを追加
  24. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the FSC board screws: 手順 24、 2の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the FSC board screws: 手順 24、 2の画像 2
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
    FixBotに聞いてみる
    コメントを追加
  25. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the FSC board: 手順 25、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the FSC board: 手順 25、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Remove the FSC board: 手順 25、 3の画像 3
    • Remove the FSC board.
    • Use the alignment pegs to ensure the board is correctly positioned.
    FixBotに聞いてみる
    コメントを追加
  26. Steam Controller (2nd Gen, 2026) FSC Board Replacement, Transfer the FSC board cable: 手順 26、 3の画像 1 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Transfer the FSC board cable: 手順 26、 3の画像 2 Steam Controller (2nd Gen, 2026) FSC Board Replacement, Transfer the FSC board cable: 手順 26、 3の画像 3
    • If your replacement FSC board doesn't come with a cable, follow this step to transfer it.
    • Use a spudger to lift the hinged locking flap on the center ZIF connector.
    • Be very careful not to damage any of the small, surface-mounted components around the connector.
    • Slide the cable out of the socket and remove it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
Spencer Day
メンバー登録日: 09/14/22
195,262 ポイント
1,243のガイドは作成済み
1件のガイドコメント
So whyh does this have a t4 in related tools, but requires a t5 for the fsc board?
The Scout - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 170
今までの合計 716
