メインコンテンツにスキップ
Sony Vaio VPCCW17FX Webcam Replacement
Tiffani Beck
Tiffani Beck とその他 5 人の作成者
最終更新日: December 7, 2022
5 - 7 分
簡単
高画質の画像が必要
In order to remove the webcam safely, be sure to take out the battery first. The webcam is located under the plastic screen cover of the laptop.
必要な工具と部品
ツール
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: 手順 1、 1の画像 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: 手順 2、 1の画像 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: 手順 3、 2の画像 1 Sony Vaio VPCCW17FX Webcam Replacement: 手順 3、 2の画像 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: 手順 4、 2の画像 1 Sony Vaio VPCCW17FX Webcam Replacement: 手順 4、 2の画像 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: 手順 5、 2の画像 1 Sony Vaio VPCCW17FX Webcam Replacement: 手順 5、 2の画像 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: 手順 6、 3の画像 1 Sony Vaio VPCCW17FX Webcam Replacement: 手順 6、 3の画像 2 Sony Vaio VPCCW17FX Webcam Replacement: 手順 6、 3の画像 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
終わりに
作成者
5人の作成者と共同で作成されました。
Tiffani Beck
メンバー登録日: 03/20/17
219 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 1,173
