メインコンテンツにスキップ
Sony Vaio VPCCW17FX Speakers Replacement
Brianna Rukes
Brianna Rukes とその他 6 人の作成者
最終更新日: December 8, 2022
10 - 15 分
中レベル
間違いの指摘
詳細が不足
In order to remove the speakers safely, be sure to take out the battery first. The speakers are located under the bottom covering of the laptop.
必要な工具と部品
ツール
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: 手順 2、 1の画像 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: 手順 3、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 3、 2の画像 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: 手順 4、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: 手順 5、 1の画像 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: 手順 6、 1の画像 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: 手順 7、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 7、 2の画像 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: 手順 8、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 8、 2の画像 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 2 Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
終わりに
作成者
6人の作成者と共同で作成されました。
Brianna Rukes
メンバー登録日: 03/21/17
101 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 548
