メインコンテンツにスキップ
Sony FDL-220R Watchman Speaker Replacement
Sam Putnam
Sam Putnam とその他 3 人の作成者
最終更新日: May 7, 2024
30分
難しい
This guide will outline how to replace the Sony FDL-220R Watchman mono-speaker. Steps include a thorough disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver, soldering station, and tweezers.
Knowledge of how to solder a basic through-hole contact is required.
必要な工具と部品
ツール
もっと見る
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: 手順 1、 2の画像 1 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: 手順 1、 2の画像 2
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: 手順 2、 2の画像 1 Sony FDL-220R Watchman Speaker Replacement, Remove screws: 手順 2、 2の画像 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: 手順 3、 2の画像 1 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: 手順 3、 2の画像 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 手順 4、 3の画像 1 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 手順 4、 3の画像 2 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: 手順 4、 3の画像 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 手順 5、 3の画像 1 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 手順 5、 3の画像 2 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sam Putnam
メンバー登録日: 10/22/14
484 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 327
