はじめに
This guide will show you how to clean and/or replace the buttons and switches on the Sony FDL-220R Watchman. Steps include basic disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver and a solution of warm water and baking soda.
必要な工具と部品
Press down on the textured area and push towards the bottom of the device.
Gently remove the battery cover.
Remove the three AA batteries.
Locate the five 5x11mm screws surrounding the battery compartment.
Remove screws with a Philips #00 screwdriver.
Grasp the entire back half of the Watchman's casing.
Snap off the casing from the bottom of the device.
Gently pull off entire back casing.
Carefully grasp the entire circuit board.
Pull the circuit board off of the device's plastic casing.
Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
Remove all three buttons/switches.
If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
If one of the buttons/switches is broken, simply replace it with a new one.
