メインコンテンツにスキップ
Sony FDL-220R Watchman Antenna Replacement
Sam Putnam
Sam Putnam とその他 2 人の作成者
最終更新日: January 9, 2015
10分
中レベル
This guide will outline how to disassemble and reattach or replace the Sony FDL-220R Watchman antenna. Steps include basic disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver and a Spudger.
必要な工具と部品
ツール
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: 手順 1、 2の画像 1 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: 手順 1、 2の画像 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: 手順 2、 2の画像 1 Sony FDL-220R Watchman Antenna Replacement, Remove screws: 手順 2、 2の画像 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: 手順 3、 2の画像 1 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: 手順 3、 2の画像 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 手順 4、 3の画像 1 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 手順 4、 3の画像 2 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 手順 4、 3の画像 3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
終わりに
作成者
2人の作成者と共同で作成されました。
Sam Putnam
メンバー登録日: 10/22/14
484 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 526
