Open the flash/ lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
Use the spudger to release the latch for the shutter mechanism.
Rotate the shutter mechanism clockwise until it stops.
How do you remove the plastic plate in front of the exposure wheel? I see it in step 6 under the lens but not in the photos for step 7 and it seems to be blocking a tab in step 8. Thanks!
Did you ever figure out how to remove the plastic piece. I’m struggling with this same issue now.
Has anybody figured it out in the end, I’m yet another person struggling with this
Figured it out, there’s a little black plastic tang that needs to be pushed downward, and is the only piece holding the clear plastic slide down.
To replace the shutter pieces in the camera, first make sure they are in the proper order.
The shutter piece at the bottom of the first picture belongs on the bottom.
The shutter piece in the middle of the first picture goes in the middle (second picture).
The shutter piece at the top of the first picture goes on top (third picture).
Align teal and orange circled tabs from the first picture with the respective teal and orange holes in the shutter pieces.
After the shutter mechanism is placed into the camera, make sure all three shutter pieces are attached correctly.
To finish putting the Polaroid back together, follow steps 9 through 1 in reverse.
7 の人々がこのガイドを完成させました。
