Removing the HP Elitebook 6930p Top Cover
はじめに
手順 1 に進むThis guide shows how to remove the top cover, the top cover includes the track pad and finger print scanner.
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
Lift the left side of the bay cover and swing it up and to the right to remove it.
Loosen the M2.5×10.0 captive screw that holds the hard drive in.
Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
Lift the hard drive straight up and out of the laptop.
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Remove the two M2.0×4.0 broad-head screws.
Remove the three Torx T8 M2.5×7.0 screws.
Close the lid and turn the laptop so the rear is facing you
Locate and remove the two Torx T8 2.5×7.0 screws at each corner
Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees.
Locate and disconnect the display panel cable.
Locate and disconnect the microphone cable.
Locate and disconnect the webcam cable.
Locate and disconnect the 3 antenna cables.
Unclip the antenna cables from the retaining clips.
NOTE There are 2 antenna cables that go from the display assembly through the hole shown and connect to the WWAN (3G) WiFi card if it is installed. In my case they were just threaded into the hole to make things tidy as I didn't have a WWAN card.
Turn the laptop upside down with the front toward you.
Locate and remove seven Torx T8 2.5×7.0 screws.
Locate and remove one Philips M2.0×5.0 screw.
Turn the laptop right-side up with the front toward you.
Release the three ZIF connectors and disconnect the ribbon cables.
This cable is routed over the top cover and needs to be disconnected at one end to allow the top cover to be removed.
Remove the RTC battery from its holder
9 の人々がこのガイドを完成させました。
3ガイドコメント
Excellent and concise instructions. Thank you.
Excellent, I have been looking for this kind of perfect description
Asia Goldy - 返信
