Razer Basilisk V3 Side and Middle Scroll Wheel Buttons Replacement
はじめに
手順 1 に進むThis guide provides detailed instructions for replacing the side-to-side scroll wheel buttons (SW2 and SW4) and the middle scroll wheel click button (SW3) on the Razer Basilisk V3. These components are essential for smooth scrolling and clicking actions during use. Replacement may be needed if the buttons become unresponsive or feel inconsistent.
Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
Remove six 4 mm screws using a JIS #0 screwdriver.
Insert the flat end of a spudger in the gap between the motherboard and the rest of the mouse.
Slowly pry up the edge of the board, moving around the mouse slowly in a counterclockwise direction.
Identify SW2, SW3, and SW4 which are marked on the motherboard.
Use a soldering iron and desoldering pump or solder wick to remove the old solder from SW2, SW3, and SW4.
Once the solder is removed, use tweezers to carefully lift and remove the old button modules from the motherboard.
ある他の人がこのガイドを完成しました。
