Philips Sonicare HX6710 Replacing the Battery
はじめに
手順 1 に進むMost common issue with this is the difficulty with which to open it up.
Remove the brush head
Using a thin screwdriver carefully pry open the bottom of the case.
Have a look to an alternative opening procedure.
Remove lower cap (2 plastic tabs). O-ring is already removed in this picture.
Here are the solder connections of the battery: + (red) and - (yellow).
Unwrap the battery and replace it (see Soldering Skills).
To avoid a short circuit (the battery will normally still have a remaining charge), start at the positive pole of the battery and unsolder completely from the board.
Continue with the negative pole.
At the end, loosen the soldering pads from remaining solder, so that the contacts of the new battery can be inserted into the board.
Solder teh positive and negative pole.
Requires a 3.7V battery, which is approximately 14mm x 49mm (similar to AA).
Before assembly, check the upper seal and the lower O-ring and replace those if necessary.
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
コメント 1 件
I saw in another guide that it is advisable, before working on the Li-Ion battery, to break the join between the two pads of JP1 which disconnects the battery.
This is very important due to the volatile nature of Lithium-Ion batteries.
It also takes away some risk of shorting out the battery when we remove it.
So with the solder, before working, break the join between the two pads of JP1.
And at the end, after replaced the battery, re-join the two solder pads of JP1.
