メインコンテンツにスキップ
Philips Sonicare 2 Series Battery Replacement
Jonathan Jarvis
Jonathan Jarvis とその他 6 人の作成者
最終更新日: January 27, 2025
20 - 50 分
難しい
Use this guide to replace a worn-out battery on your Philips Sonicare 2 Series (Model HX62**-**) toothbrush. This procedure requires soldering. If you don’t know how to solder, use this guide.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Philips Sonicare 2 Series Battery Replacement, Philips Sonicare 2 Series Disassembly: 手順 1、 1の画像 1
    • Pull upwards to remove the brush head from the top of the device.
  2. Philips Sonicare 2 Series Battery Replacement: 手順 2、 1の画像 1
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
  3. Philips Sonicare 2 Series Battery Replacement: 手順 3、 2の画像 1 Philips Sonicare 2 Series Battery Replacement: 手順 3、 2の画像 2
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
  4. Philips Sonicare 2 Series Battery Replacement: 手順 4、 1の画像 1
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
  5. Philips Sonicare 2 Series Battery Replacement: 手順 5、 1の画像 1
    • Remove the white battery cover as shown in the figure.
  6. Philips Sonicare 2 Series Battery Replacement: 手順 6、 1の画像 1
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
  7. Philips Sonicare 2 Series Battery Replacement, Battery: 手順 7、 1の画像 1
    • Use a plastic spudger to pry the battery up at an angle, partially removing it from the internal frame.
    • This won't completely remove the battery, as it is still soldered to the mainboard.
    • Do not use a metal pry tool to complete this step. You may puncture the battery pack, possibly leading to leakage, fire, or explosion.
  8. Philips Sonicare 2 Series Battery Replacement: 手順 8、 1の画像 1
    • Desolder the two indicated battery connections on the mainboard.
  9. Philips Sonicare 2 Series Battery Replacement: 手順 9、 3の画像 1 Philips Sonicare 2 Series Battery Replacement: 手順 9、 3の画像 2 Philips Sonicare 2 Series Battery Replacement: 手順 9、 3の画像 3
    • Well, the VOLTAGE of this battery is about 2.8 to 2.9 Volts. The size is same as that of TWO AAA Cells. Two AAA in series can easily replace the existing battery. Ni-Mh AAA cells of Energizer can do the job. Disconnect the existing battery but don’t remove the metallic connection to the circuit.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jonathan Jarvis
メンバー登録日: 04/01/16
515 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S6-G2, Baechle Fall 2017 IUPUI, Team S6-G2, Baechle Fall 2017人のメンバー
IUPUI-BAECHLE-F17S6G2
3 メンバー
8のガイドは作成済み
7 件のコメント
Step 3 is incorrect. The only things keeping the internals secured in the casing are the two ‘elbows’ clearly visible in Step 3 picture 2. Simply pry these away from the depressions in the casing and the works slide out, with a little push from the top stem. The method describing the 3 red clips does no good (besides being nearly impossible to accomplish) and presents a clear risk of breaking the hair-thin wires
craig chatfield - 返信
The method described in Step 3 to remove the internals from the casing is incorrect. Rather than prying the 3 red clips (nearly impossible anyhow) all that is required is to pry the two ‘elbows’ visible in step 3, photo 2, away from the depressions in the casing. Voila.
The two comments are correct, the earlier teardown is from a much earlier Sonicare. All the current models just need a spatula to depress the white detents while applying pressure gently from the brush end. The assembly will then easily pop right out.
jhuffaker - 返信
How to get a new battery for this Philips Sonicare 2 Plaque control toothbrush.
Ni-Mh AAA cells of energizer can do the job. Disconnect the existing battery but don’t remove the metallic connection to the circuit.
uniquesolutions - 返信
Thank you for the comments about removing the “innards”. I spent a couple hours yesterday trying to remove those red clips! This morning I saw the comments. It’s still a little bit of a challenge to get both elbows pried, but I found out it’s easier if you apply quite a bit of pressure to the brush end while manipulating the elbows. At first I was trying to light of pressure and the opposite elbow would always fall back into the depression while I tried to pry the other side. More pressure and the problem was resolved. Again, thanks to Craig for his observation. ifixit needs to correct the above instructions to reflect this.
lindajohnjosie - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 24
過去 30 日: 72
今までの合計 10,385
