メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Opening Procedure
必要な工具と部品
    1. Opening Procedure, Power down your watch: 手順 1、 2の画像 1 Opening Procedure, Power down your watch: 手順 1、 2の画像 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      FixBotに聞いてみる
      コメントを追加
    2. Opening Procedure, Unfasten the back cover: 手順 2、 1の画像 1
      • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
      FixBotに聞いてみる
      コメントを追加
    3. Opening Procedure, Loosen the back cover adhesive: 手順 3、 1の画像 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      FixBotに聞いてみる
      コメントを追加
    4. Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 1 Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 2 Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 3
      • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
      • Pry upwards to loosen the back cover assembly. This may require some force.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
      • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
      FixBotに聞いてみる
      コメントを追加
    5. Opening Procedure, Disconnect the sensor assembly cable: 手順 5、 2の画像 1 Opening Procedure, Disconnect the sensor assembly cable: 手順 5、 2の画像 2
      • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBotに聞いてみる
      コメントを追加
    6. Opening Procedure, Remove the back cover assembly: 手順 6、 3の画像 1 Opening Procedure, Remove the back cover assembly: 手順 6、 3の画像 2 Opening Procedure, Remove the back cover assembly: 手順 6、 3の画像 3
      • Remove the back cover assembly.
      FixBotに聞いてみる
      コメントを追加
終わりに
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
262,273 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
40,890のガイドは作成済み
2件のガイドコメント
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - 返信 共有
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 58
今までの合計 2,426
