はじめに
If your OnePlus 12 is experiencing battery drainage issues or won’t hold a charge/won’t charge, then it may be time to replace the phone’s battery.
For your safety, discharge your battery below 20% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
This repair involves removing the phone's back glass. You will need replacement adhesive for it or may even need a replacement back glass in order to complete this repair.
必要な工具と部品
Ensure the phone is powered off and placed with the back glass facing towards you on a stable surface.
この手順で使用する道具:Jimmy$7.95
Insert a Jimmy into the seam of the back glass to lift it slightly. Try to reduce pressure on any single spot of the glass to avoid cracking it.
Insert a plastic card underneath the small gap created on the back glass and gently glide the card under the lifted glass.
Remove the back glass from the phone by working your way around the glass slowly. You may need to re-heat after a while to keep the glue soft. Otherwise, you may shatter the glass.
Remove the twelve Phillips #0 screws from the motherboard plastic.
Remove the eight Phillips #0 screws from the bottom plastic.
Insert a Jimmy between the motherboard plastic and the frame of the phone, then gently pry up to unclip the plastic.
The motherboard plastic can lift up and out of the phone. The wireless charging coil is part of the plastic, so be mindful of it when moving the plastic.
Undo the battery press connector with a plastic spudger or tool.
Disconnect the coaxial connector carefully.
Gently release the wire from the cable guide by pulling it up and out. It has some retaining force but there is no clip or latch.
Insert your Jimmy on the other side of the bottom plastic between the frame and the plastic, then gently pry up to pop out the plastic just like the speaker.
Undo the press connector for the communication flex cable.
Undo the other press connector for the communication flex cable with a plastic spudger or tool.
With the two press connectors for the communication flex cable removed, you can remove the flex cable and set it aside.
Use your fingernail to get the battery pull tabs unstuck
Grab ahold of one battery pull tab with one hand and stabilize the phone with the other. I like to hold the phone by the frame with the other hand. You can then start pulling the pull tab directly away from the phone - don't pull it to the side.
