メインコンテンツにスキップ
Nostalgia Electrics PCM805 Heating Element
Nicholas Fazio
Nicholas Fazio とその他 5 人の作成者
最終更新日: August 9, 2019
30分
中レベル
Use this guide to replace your heating element if it has stopped working.
必要な工具と部品
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Nostalgia Electrics PCM805 Heating Element, Bowl: 手順 1、 1の画像 1
    • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
    • Place the device on a steady table.
    • Lift and remove the rim.
  2. Nostalgia Electrics PCM805 Heating Element: 手順 2、 3の画像 1 Nostalgia Electrics PCM805 Heating Element: 手順 2、 3の画像 2 Nostalgia Electrics PCM805 Heating Element: 手順 2、 3の画像 3
    • Twist the bowl clockwise until it is free of the groove and lift to remove.
  3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: 手順 3、 2の画像 1 Nostalgia Electrics PCM805 Heating Element, Extractor Head: 手順 3、 2の画像 2
    • Firmly grip the extractor head and slowly lift vertically to remove from the device.
    I need the extractor piece for my machine. Can I get it
    sungiddess196626 - 返信
  4. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 手順 4、 2の画像 1 Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 手順 4、 2の画像 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  5. Nostalgia Electrics PCM805 Heating Element: 手順 5、 1の画像 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  6. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 手順 6、 2の画像 1 Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 手順 6、 2の画像 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  7. Nostalgia Electrics PCM805 Heating Element: 手順 7、 3の画像 1 Nostalgia Electrics PCM805 Heating Element: 手順 7、 3の画像 2 Nostalgia Electrics PCM805 Heating Element: 手順 7、 3の画像 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  8. Nostalgia Electrics PCM805 Heating Element, Heating Element: 手順 8、 2の画像 1 Nostalgia Electrics PCM805 Heating Element, Heating Element: 手順 8、 2の画像 2
    • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
    • Remove the metal housing.
  9. Nostalgia Electrics PCM805 Heating Element: 手順 9、 2の画像 1 Nostalgia Electrics PCM805 Heating Element: 手順 9、 2の画像 2
    • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
  10. Nostalgia Electrics PCM805 Heating Element: 手順 10、 2の画像 1 Nostalgia Electrics PCM805 Heating Element: 手順 10、 2の画像 2
    • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Nicholas Fazio
メンバー登録日: 01/13/15
194 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015人のメンバー
USFT-HICKMAN-W15S3G5
5 メンバー
8のガイドは作成済み
1ガイドコメント
Where can I buy a replacement heating element?
Eric P. Rose - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 31
今までの合計 5,659
