メインコンテンツにスキップ
Nikon Coolpix L330 Motherboard Replacement
Mohammed Al Rawahi
Mohammed Al Rawahi とその他 3 人の作成者
最終更新日: June 28, 2020
30 - 40 分
難しい
If you encounter issues with your camera motherboard, follow this step by step guide to aid you on replacing it.
必要な工具と部品
ツール
もっと見る
  1. Nikon Coolpix L330 Motherboard Replacement, Back Housing: 手順 1、 3の画像 1 Nikon Coolpix L330 Motherboard Replacement, Back Housing: 手順 1、 3の画像 2 Nikon Coolpix L330 Motherboard Replacement, Back Housing: 手順 1、 3の画像 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Motherboard Replacement: 手順 2、 2の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 2、 2の画像 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 Motherboard Replacement, LCD Screen: 手順 3、 2の画像 1 Nikon Coolpix L330 Motherboard Replacement, LCD Screen: 手順 3、 2の画像 2
    • Insert the tips of your fingers into the space between the screen and back-plate.
    • Gently lift the screen up and out of the frame.
    • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
  4. Nikon Coolpix L330 Motherboard Replacement: 手順 4、 2の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 4、 2の画像 2
    • Tilt the screen so that the display cable forms a hinge with the backplate.
    • Rotate the display 180 degrees so that it faces you.
  5. Nikon Coolpix L330 Motherboard Replacement: 手順 5、 3の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 5、 3の画像 2 Nikon Coolpix L330 Motherboard Replacement: 手順 5、 3の画像 3
    • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
    • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
    • Slide the display cable out of the connector.
    • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
  6. Nikon Coolpix L330 Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the screws from the silver back-plate with a PH000 screw head.
    • Two 1.5x2.5mm screws on the left side.
    • One 1.5x2.5mm screw on the right side.
  7. Nikon Coolpix L330 Motherboard Replacement: 手順 7、 1の画像 1
    • The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
    • Remove the screws holding the motherboard with a PH000 screw head.
  8. Nikon Coolpix L330 Motherboard Replacement: 手順 8、 1の画像 1
    • Using a plastic opening tool or fingernail, pop up the black clips holding the ribbon cables. This will release the cables.
    • Slide the ribbon cables out of the connectors.
  9. Nikon Coolpix L330 Motherboard Replacement: 手順 9、 3の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 9、 3の画像 2 Nikon Coolpix L330 Motherboard Replacement: 手順 9、 3の画像 3
    • Remove the black sticker covering the electrical connections.
    • Desolder the eight wires from the motherboard.
  10. Nikon Coolpix L330 Motherboard Replacement: 手順 10、 3の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 10、 3の画像 2 Nikon Coolpix L330 Motherboard Replacement: 手順 10、 3の画像 3
    • Insert a plastic opening tool into the marked position. Push the tool towards the right to release the clip.
    • Using a thumb and forefinger, push the plastic cover up until it is at a 45 degree angle.
    • Pull the cover back and up to release it.
  11. Nikon Coolpix L330 Motherboard Replacement: 手順 11、 2の画像 1 Nikon Coolpix L330 Motherboard Replacement: 手順 11、 2の画像 2
    • The motherboard is still held in place by soldered connections.
    • Carefully desolder the connections .
    • The front cover has been removed in this picture, however the procedure is still the same.
  12. Nikon Coolpix L330 Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the motherboard by lifting it directly up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Mohammed Al Rawahi
メンバー登録日: 02/09/16
113 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-10, Cagle Spring 2016 USF Tampa, Team 2-10, Cagle Spring 2016人のメンバー
USFT-CAGLE-S16S2G10
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 834
