Mountain Bike Brake Lever Replacement
はじめに
手順 1 に進むThis guide is for those looking to replace their brake lever assembly on a mountain bike. It is a fairly simple task that does not require much prior bike knowledge. It only requires a 5mm Allen key, the lever assembly, isopropyl alcohol, and the bike.
必要な工具と部品
パーツ
ツール
もっと見る
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
2 の人々がこのガイドを完成させました。
