メインコンテンツにスキップ
Motorola Edge Earpiece Speaker Replacement
必要な工具と部品
  1. Motorola Edge Earpiece Speaker Replacement, Find the SIM tray: 手順 1、 1の画像 1
    • Find the SIM tray located at the top of the phone.
  2. Motorola Edge Earpiece Speaker Replacement, Eject the SIM tray: 手順 2、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Eject the SIM tray: 手順 2、 2の画像 2
    • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
    • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
    • Press to eject the tray.
  3. Motorola Edge Earpiece Speaker Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 3
    • Remove the SIM card tray from the phone.
  4. Motorola Edge Earpiece Speaker Replacement, Heat the bottom edge: 手順 4、 1の画像 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  5. Motorola Edge Earpiece Speaker Replacement, Separate the bottom adhesive: 手順 5、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Separate the bottom adhesive: 手順 5、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Separate the bottom adhesive: 手順 5、 3の画像 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  6. Motorola Edge Earpiece Speaker Replacement, Slice the bottom adhesive: 手順 6、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Slice the bottom adhesive: 手順 6、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Slice the bottom adhesive: 手順 6、 3の画像 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Motorola Edge Earpiece Speaker Replacement, Heat the right edge: 手順 7、 1の画像 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge Earpiece Speaker Replacement, Separate the corner adhesive: 手順 8、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Separate the corner adhesive: 手順 8、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Separate the corner adhesive: 手順 8、 3の画像 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  9. Motorola Edge Earpiece Speaker Replacement, Separate the right adhesive: 手順 9、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Separate the right adhesive: 手順 9、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Separate the right adhesive: 手順 9、 3の画像 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  10. Motorola Edge Earpiece Speaker Replacement, Remove the back cover: 手順 10、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the back cover: 手順 10、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the back cover: 手順 10、 3の画像 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  11. Motorola Edge Earpiece Speaker Replacement, Remove the motherboard's screws: 手順 11、 1の画像 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  12. Motorola Edge Earpiece Speaker Replacement, Remove the motherboard cover: 手順 12、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the motherboard cover: 手順 12、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the motherboard cover: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  13. Motorola Edge Earpiece Speaker Replacement, Disconnect the battery cable's press connector: 手順 13、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the battery cable's press connector: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Motorola Edge Earpiece Speaker Replacement, Disconnect the interconnect cable from the motherboard: 手順 14、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the interconnect cable from the motherboard: 手順 14、 2の画像 2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  15. Motorola Edge Earpiece Speaker Replacement, Disconnect the screen ribbon cable's press connector: 手順 15、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the screen ribbon cable's press connector: 手順 15、 2の画像 2
    • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
  16. Motorola Edge Earpiece Speaker Replacement, Remove the copper tape: 手順 16、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the copper tape: 手順 16、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the copper tape: 手順 16、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
  17. Motorola Edge Earpiece Speaker Replacement, Remove the front camera cable's press connector: 手順 17、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the front camera cable's press connector: 手順 17、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the front camera cable's press connector: 手順 17、 3の画像 3
    • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
    • Remove the front camera.
  18. Motorola Edge Earpiece Speaker Replacement, Remove the wide angle camera's press connector: 手順 18、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the wide angle camera's press connector: 手順 18、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the wide angle camera's press connector: 手順 18、 3の画像 3
    • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
    • Remove the wide angle camera.
  19. Motorola Edge Earpiece Speaker Replacement, Remove the main camera cable's press connector: 手順 19、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the main camera cable's press connector: 手順 19、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the main camera cable's press connector: 手順 19、 3の画像 3
    • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
    • Remove the main camera.
  20. Motorola Edge Earpiece Speaker Replacement, Remove the telephoto camera's press connector: 手順 20、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the telephoto camera's press connector: 手順 20、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the telephoto camera's press connector: 手順 20、 3の画像 3
    • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
    • Remove the telephoto camera.
  21. Motorola Edge Earpiece Speaker Replacement, Disconnect the black coaxial cable: 手順 21、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the black coaxial cable: 手順 21、 2の画像 2
    • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
  22. Motorola Edge Earpiece Speaker Replacement, Disconnect the white coaxial cable: 手順 22、 2の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the white coaxial cable: 手順 22、 2の画像 2
    • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
  23. Motorola Edge Earpiece Speaker Replacement, Remove the motherboard: 手順 23、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the motherboard: 手順 23、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the motherboard: 手順 23、 3の画像 3
    • Use a spudger to pry up and remove the motherboard.
    • Make sure no cables get trapped under the motherboard during reassembly.
  24. Motorola Edge Earpiece Speaker Replacement, Weaken the earpiece speaker's adhesive: 手順 24、 1の画像 1
    • Apply a drop or two of isopropyl alcohol to weaken the adhesive securing the earpiece speaker.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
    • The adhesive is located both under the ribbon cable and under the earpiece speaker.
  25. Motorola Edge Earpiece Speaker Replacement, Disconnect the earpiece speaker cable: 手順 25、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Disconnect the earpiece speaker cable: 手順 25、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Disconnect the earpiece speaker cable: 手順 25、 3の画像 3
    • Use an opening pick to disconnect the earpiece speaker cable from the midframe.
  26. Motorola Edge Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 26、 3の画像 1 Motorola Edge Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 26、 3の画像 2 Motorola Edge Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 26、 3の画像 3
    • Pry at the edge of the earpiece speaker with a spudger to detach it from the frame.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing the earpiece speaker.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the earpiece speaker.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
作成者
2人の作成者と共同で作成されました。
Jennifer Berg
メンバー登録日: 03/21/22
2,759 ポイント
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 13
今までの合計 406
