メインコンテンツにスキップ
Mavic 2 Main Board  Replacement
Robert Contraction
Robert Contraction とその他 3 人の作成者
最終更新日: July 31, 2024
20 - 30 分
簡単
  1. Turn drone upside down to expose underside plate.
  2. Begin to remove all 8 screws from the plate . Remember the 2 middle screws are bigger than the other 6 so set those aside separately.
  3. Pull plate off, exposing the main board.
  4. Detach 3 ribbons on the top of the board. Near the head of the drone. Use spreader.
  5. Remove screw holding circuit board in. 1 near the top, 2 near the bottom.
  6. Pop of all 4 antennas at the bottom of the circuit board. Use spreader.
  7. Pull away antennas and remove board carefully.
  8. Replace new circuit board.
  9. Attach 3 ribbons.
  10. Attach 4 antennas.
  11. Screw circuit board back in.
  12. Place the plate back on and screw back in all 8 screws.
必要な工具と部品
  1. Mavic 2 Main Board  Replacement, Remove screws: 手順 1、 1の画像 1
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: 手順 2、 3の画像 1 Mavic 2 Main Board  Replacement, Continue to remove screws: 手順 2、 3の画像 2 Mavic 2 Main Board  Replacement, Continue to remove screws: 手順 2、 3の画像 3
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: 手順 3、 2の画像 1 Mavic 2 Main Board  Replacement: 手順 3、 2の画像 2
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: 手順 4、 1の画像 1
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: 手順 5、 1の画像 1
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Robert Contraction
メンバー登録日: 11/26/19
175 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S15-G3, Barthe Fall 2019 UMass Dartmouth, Team S15-G3, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S15G3
1 メンバー
1のガイドは作成済み
コメント 1 件
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 34
今までの合計 1,484
