Mac mini Late 2012 Heat Sink Replacement
はじめに
手順 1 に進むUse this guide to replace your mini's heat sink. Reinstalling the heat sink will require a new layer of thermal paste.
必要な工具と部品
パーツ
ツール
もっと見る
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
この手順で使用する道具:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
Remove the following two screws securing the speaker to the logic board assembly:
One 3.5 mm T6 Torx screw
One 3.7 mm T6 Torx screw
Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
To reassemble your device, follow these instructions in reverse order. Be sure to follow our thermal paste guide to reapply the thermal compound on the CPU.
16 の人々がこのガイドを完成させました。
3 件のコメント
When reinstalling the heatsink the Platform controller chip has a huge gap, so you have to either use a thermal pad, ton of thermal paste or shim the gap. I ended up using a shim made out of a soda can. I posted photos here:
There is no need for the controller to be cooled. It is the same with the MacBooks of that time. The controller chip isnt even covered by the heatsink.
Fred -
Hello,
I'll refresh this thread a bit - I replaced the thermal paste on the processor and since then my Mac mini patch 2012 has been raging at tepmperatures between 70 and 100 degrees. What could I have screwed up? The system laughs like crazy, I rebooted and PRAM and SMC and tried with SAFE MODE , changed the paste again and same thing. Do you have any experience with this type of problem?
