メインコンテンツにスキップ
Lenovo Thinkpad T450 SSD Replacement
Justin Ogihara
Justin Ogihara とその他 人の作成者
最終更新日: September 11, 2023
10 - 25 分
中レベル
The solid-state drive (or SSD) is a storage device used to store data. SSDs are much faster than the traditional hard-disc drives (HDD) due to their physical nature. Unlike the standard HDD, an SSD does not have a physical spinning disc in the component. Current estimates show that SSDs may reach a lifespan of 10 years, but the average lifespan of a SSD is shorter.
If your Lenovo ThinkPad T450 laptop is not properly loading files or is slow to load, it may be time to replace the SSD. Follow these instructions to replace the SSD in your device.
必要な工具と部品
修理キット
キットには、この修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. Lenovo Thinkpad T450 SSD Replacement, External Battery: 手順 1、 3の画像 1 Lenovo Thinkpad T450 SSD Replacement, External Battery: 手順 1、 3の画像 2 Lenovo Thinkpad T450 SSD Replacement, External Battery: 手順 1、 3の画像 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 SSD Replacement, Back Cover: 手順 2、 1の画像 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 SSD Replacement: 手順 3、 3の画像 1 Lenovo Thinkpad T450 SSD Replacement: 手順 3、 3の画像 2 Lenovo Thinkpad T450 SSD Replacement: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 SSD Replacement, SSD: 手順 4、 1の画像 1
    • Using the JIS #00 screwdriver, remove the single 2.8 mm screw securing the SSD to the device.
  5. Lenovo Thinkpad T450 SSD Replacement: 手順 5、 2の画像 1 Lenovo Thinkpad T450 SSD Replacement: 手順 5、 2の画像 2
    • Lift the SSD up and to the left and remove it from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Justin Ogihara
メンバー登録日: 09/18/17
29,042 ポイント
52のガイドは作成済み
チーム
EDU Team EDU Team人のメンバー
Staff
7 メンバー
753のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 27
過去 30 日: 135
今までの合計 5,646
