メインコンテンツにスキップ
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
Eevee Murdock
Eevee Murdock とその他 2 人の作成者
最終更新日: June 10, 2020
15 - 45 分
中レベル
If your Lenovo ThinkPad X1 Carbon (2nd Gen) charger will not work, the screen randomly turns blue, or the laptop randomly freezes, use this guide to replace the motherboard.
The motherboard allows all of the components of your computer to communicate with each other.
Before using this guide, if the charger will not work, try using a few different outlets to charge your computer and check that your battery firmware is updated.
Also, try turning it completely off and on again.
Before you begin, make sure your computer is off.
必要な工具と部品
ツール
もっと見る
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: 手順 1、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 手順 3、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 手順 3、 2の画像 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 4、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 5、 1の画像 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: 手順 6、 1の画像 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 7、 1の画像 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 8、 1の画像 1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 手順 9、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 手順 9、 2の画像 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 10、 2の画像 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 11、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 12、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 13、 2の画像 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 14、 1の画像 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 15、 2の画像 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 16、 2の画像 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Eevee Murdock
メンバー登録日: 01/23/20
1,110 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020人のメンバー
CPSU-WHITE-W20S18G4
4 メンバー
9のガイドは作成済み
2 件のコメント
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - 返信
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 74
今までの合計 4,143
