メインコンテンツにスキップ
Lenovo ThinkPad T470 Bottom Cover Replacement
Kristen Gismondi
Kristen Gismondi とその他 人の作成者
最終更新日: May 23, 2024
10分
簡単
Use this guide to replace the bottom cover of your Lenovo ThinkPad T470 laptop.
The bottom cover encases the internal components of the laptop and provides proper ventilation for the fan. You may need to replace the bottom cover if it is cracked or physically damaged to the point where it is exposing the laptop’s internals.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
必要な工具と部品
ツール
  1. Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: 手順 1、 3の画像 1 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: 手順 1、 3の画像 2 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: 手順 1、 3の画像 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 2、 3の画像 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: 手順 3、 2の画像 1 Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: 手順 3、 2の画像 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 4、 3の画像 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Bottom Cover Replacement: 手順 5、 1の画像 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,432 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,545のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 107
今までの合計 3,735
