メインコンテンツにスキップ
Lenovo Tab 2 A10-70 LCD/Digitizer Replacement
Stacy Tinner
Stacy Tinner とその他 人の作成者
最終更新日: October 25, 2018
25分
難しい
In order to remove the tablet screen, removal of the battery and motherboard is necessary.
必要な工具と部品
ツール
もっと見る
  1. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement, Battery: 手順 1、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement, Battery: 手順 1、 2の画像 2
    • Before removing the battery, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet.
    • The second picture shows the tablet with the back removed.
  2. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    • Remove the tape that secures the ribbon cable.
    • Use precision tweezers if the tape cannot be removed by hand.
  3. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 3、 1の画像 1
    • Handle ribbon cables with care so it does not rip or tear.
    • Carefully remove the ribbon cable from the power button connector.
    • To remove the cable, push the clamp on the connector up and pull gently.
  4. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 4、 1の画像 1
    • Remove the following screws securing the metal frame holding the battery.
    • Five 2 mm Philips screws.
    • Use either the Phillips #00 or #000 bit to remove the screws.
  5. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 5、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 5、 2の画像 2
    • Remove the grey tape.
    • Unscrew the hidden 2mm screw using the Phillips #000 drill bit.
  6. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 6、 1の画像 1
    • Remove the second piece of tape from the other ribbon cable connected to the battery.
  7. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 7、 1の画像 1
    • Remove the screws securing the battery connector cover.
    • Two 2mm Phillips screws.
  8. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 8、 1の画像 1
    • Once the screws are removed, remove the metal cover shown.
  9. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 9、 1の画像 1
    • Gently remove the following:
    • Disconnect the battery ribbon cable.
  10. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 10、 1の画像 1
    • Once the battery ribbon cable is detached, carefully remove the battery.
  11. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement, LCD/Digitizer: 手順 11、 1の画像 1
    • Remove the following screws using the Phillips 000 drill bit.
    • Eleven 4 mm screws
  12. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 12、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 12、 2の画像 2
    • Carefully disconnect the ribbon cable on the motherboard.
    • To remove the cable, push the connector on the clamp up and gently pull.
  13. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 13、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 13、 2の画像 2
    • Disconnect the other end of the motherboard ribbon cable.
    • The other end is attached to the frame of the tablet with adhesive. Gently pry it up to remove it.
  14. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 14、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 14、 2の画像 2
    • The speakers of the tablet are connected to the motherboard.
    • Parts of the motherboard are secured to the frame of the tablet with adhesive. Gently pry up to remove from the tablet.
    • The wire connected to the motherboard can be removed by lifting them from their shown slots.
  15. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 15、 1の画像 1
    • Remove the pieces of tape attaching the frame of the tablet to the screen
    • Ten pieces of grey tape.
  16. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 16、 2の画像 1 Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 16、 2の画像 2
    • The screen is secured by adhesive around all the edges of the screen.
    • Remove the screen from the frame of the tablet
    • Heat up the adhesive and gently pry the screen away with the plastic opening tool.
  17. Lenovo Tab 2 A10-70 LCD/Digitizer Replacement: 手順 17、 1の画像 1
    • Separate the screen from the digitizer.
    • Heat up the adhesive securing the screen and pry it away using the plastic opening tool.
終わりに
17 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Stacy Tinner
メンバー登録日: 02/08/16
1,433 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 12-6, Eyestone Spring 2016 USF Tampa, Team 12-6, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S12G6
4 メンバー
10のガイドは作成済み
6 件のコメント
how did you keep the digitizer intact?my problem is the lcd screen and I bought only that.too scared to start without knowing how to keep the digitizer intact as it would take weeks before I could replace it.also wondering how to replace the lcd and only that.could you help me please?
Hans Sorensen ,Norway
project_81 - 返信
In my personal opinion, this guide have a bunch of steps that aren't necessary. I just replaced a cracked one. And I just removed the battery for security purposes since I was going to use heat. But you don't have to remove the mother board or anything else, just disconnect the digitizer flex and then start prying on front. That's it.
Joel Perez - 返信
https://youtu.be/etxKSTK3Gno?t=8m19s
Is that black tape important? I wasn't lucky and it was torn.
voneout - 返信
How do you calibrate the digitizer afterwards?
Nikos Metaxas - 返信
Step 11 talks about using a Phillips 000 drill bit, rather than screwdriver, to remove the screws.
Rob Schofield M.Sc. MIET - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 11
過去 30 日: 34
今までの合計 19,172
