メインコンテンツにスキップ
Lenovo Legion Y530-15ICH Wifi Card Replacement
P_enta
P_enta とその他 2 人の作成者
最終更新日: June 26, 2024
5分
とても簡単
コミュニティメンバーによる寄稿ガイド
Most of these laptops were shipped with a trash wifi card that disconnects constantly. The Realtek 8822BE. That’s probably why you are here. Don’t worry, it’s simple to remove and replace.
必要な工具と部品
ツール
  1. Lenovo Legion Y530-15ICH Wifi Card Replacement, Remove the back plate: 手順 1、 1の画像 1
    • Remove the 5 long and 6 short Phillips head screws on the back of the computer (I am missing one). They are located around the perimeter of the bottom as well as one in the center of the fan grille. Take off the back cover.
    working with a computer on the carpet is a death sentence holy
    Ayush Kumar - 返信
  2. Lenovo Legion Y530-15ICH Wifi Card Replacement, Locate the Wifi Card: 手順 2、 1の画像 1
    • The wifi card is directly above the battery and under the right fan.
    • Remove the connections to the antenna for the card. On my Realtek 8822BE model they are white and black. Yours may be a different color but the process is identical
  3. Lenovo Legion Y530-15ICH Wifi Card Replacement, Unscrew the Wifi Card: 手順 4、 1の画像 1
    • Use the same Phillips driver you used to open the case and unscrew the card. Be careful.
  4. Lenovo Legion Y530-15ICH Wifi Card Replacement, Carefully remove the card: 手順 5、 1の画像 1
    • Pull gently and the card will remove. To put in a new card just repeat these steps in reverse.
終わりに
To reassemble your device, follow these instructions in reverse order. Be sure to keep your hands dry and be careful with electronics.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
P_enta
メンバー登録日: 12/12/20
368 ポイント
1ガイドが承認済み
4 件のコメント
which alternative do you recommend?
Vineet Gandham - 返信
Is there a list of compatible WiFi cards? I've read that the Intel AX210/211 may also be compatible, but I haven't been able to get any confirmation.
Ken walia - 返信
Mine lenovo Legion Y530-15ICH not boots with new AX211NGW
Roland Eihe - 返信
Is there any restriction in BIOS for Wifi Card Replacement?
for Lenovo Legion Y530-15ICH Laptop, serial: PF1JD34B
Gev Artanyan - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 94
今までの合計 5,796
