Lenovo Legion Y530-15ICH Motherboard Replacement
はじめに
手順 1 に進むThe motherboard acts as the central hub of communication between all of the components in your device. If random applications are quitting or if you’re seeing the “blue screen of death” (BSoD), it may be time to replace the motherboard in your computer. This guide will go through the steps on how to replace the motherboard of the Lenovo Legion Y530-15ICH.
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7mm screws
Two 6mm screws
Four 4mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
4 の人々がこのガイドを完成させました。
3 件のコメント
Kaylie Klausing
I hope you burn in !&&*
Safwat Ali - 返信
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
Safwat Ali - 返信
What the hell is wrong with this guy?
