メインコンテンツにスキップ
Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement
Nico Magtoto
Nico Magtoto とその他 6 人の作成者
最終更新日: May 7, 2024
20分
簡単
This guide will walk you through the process of removing the cooling fans in your Lenovo IdeaPad Flex 6-14IKB. This guide is helpful if your laptop is overheating. Your fans may need to be replaced, or simply cleaned if they are clogged with dust. Removing the fan is a simple task, but it is important to make sure you have thermal paste on hand for when it is time to reinstall the fan.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Base Cover: 手順 1、 1の画像 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 手順 3、 3の画像 1 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 手順 3、 3の画像 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 手順 3、 3の画像 3
    • Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
    • Loosen the seven captive screws using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to unwind the black and gray wires from the clips that are holding them onto the left side fan.
  5. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 5、 2の画像 2
    • Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
  6. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 6、 3の画像 1 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 6、 3の画像 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 6、 3の画像 3
    • Use tweezers to unplug the wiring connectors that are connected to each fan.
  7. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 手順 7、 2の画像 2
    • Gently remove the fans from the laptop.
    • There is thermal paste attaching the ducting of the fans that will require some careful prying.
    • When replacing the fan, reapply a pea sized amount of thermal paste to the fan ducts.
終わりに
作成者
6人の作成者と共同で作成されました。
Nico Magtoto
メンバー登録日: 01/09/22
489 ポイント
4のガイドは作成済み
チーム
Illinois Wesleyan University, Team 1-2, Bullock Spring 2022 Illinois Wesleyan University, Team 1-2, Bullock Spring 2022人のメンバー
IWU-BULLOCK-S22S1G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 609
