メインコンテンツにスキップ
Huawei Honor 10 Rear Glass Removal
Dominik Schnabelrauch
Dominik Schnabelrauch とその他 3 人の作成者
最終更新日: December 15, 2021
15 - 20 分
中レベル
Use this guide to remove or replace the rear glass in the Huawei Honor 10.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
ツール
もっと見る
  1. Huawei Honor 10 Rear Glass Removal, Rear Glass: 手順 1、 1の画像 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Rear Glass Removal: 手順 2、 3の画像 1 Huawei Honor 10 Rear Glass Removal: 手順 2、 3の画像 2 Huawei Honor 10 Rear Glass Removal: 手順 2、 3の画像 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Rear Glass Removal: 手順 3、 2の画像 1 Huawei Honor 10 Rear Glass Removal: 手順 3、 2の画像 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Rear Glass Removal: 手順 4、 3の画像 1 Huawei Honor 10 Rear Glass Removal: 手順 4、 3の画像 2 Huawei Honor 10 Rear Glass Removal: 手順 4、 3の画像 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Rear Glass Removal: 手順 5、 2の画像 1 Huawei Honor 10 Rear Glass Removal: 手順 5、 2の画像 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Rear Glass Removal: 手順 6、 2の画像 1 Huawei Honor 10 Rear Glass Removal: 手順 6、 2の画像 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
終わりに
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
メンバー登録日: 11/23/16
230,367 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,545のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 25
過去 30 日: 81
今までの合計 3,293
