メインコンテンツにスキップ
How to bleed the RockShox Reverb Stealth
Dominik Schnabelrauch
Dominik Schnabelrauch とその他 2 人の作成者
最終更新日: June 23, 2022
30分 - 1時間
中レベル
If your saddle doesn’t go up anymore or the system is not working correctly, it’s time to bleed your Reverb.
To avoid a mess and getting dirty wear gloves and an old shirt and keep a cleaning cloth on hand. Wear safety glasses to protect your eyes from dust and/or liquids.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 手順 1、 3の画像 1 How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 手順 1、 3の画像 2 How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 手順 1、 3の画像 3
    • Use an allen key to loosen the screws which hold the saddle in its place.
    • Remove the saddle and the upper part of its clamp.
    • Use an allen key to loosen the seat post clamp.
  2. How to bleed the RockShox Reverb Stealth: 手順 2、 3の画像 1 How to bleed the RockShox Reverb Stealth: 手順 2、 3の画像 2 How to bleed the RockShox Reverb Stealth: 手順 2、 3の画像 3
    • Remove the screw which is holding the gearshift in its place with an allen key.
    • Put the gearshifts to the side.
    • Loosen the clamp screw from the Reverb-remote until you can move it.
  3. How to bleed the RockShox Reverb Stealth: 手順 3、 3の画像 1 How to bleed the RockShox Reverb Stealth: 手順 3、 3の画像 2 How to bleed the RockShox Reverb Stealth: 手順 3、 3の画像 3
    • Install and orient the remote on the handlebar with the bleed port level, or at the highest point.
    • Remove the seatpost.
    • Attach the seatpost to the rear wheel with zip ties. Avoid any tension on the hose.
  4. How to bleed the RockShox Reverb Stealth: 手順 4、 2の画像 1 How to bleed the RockShox Reverb Stealth: 手順 4、 2の画像 2
    • Rotating the speed adjuster to the slowest setting is critical for a successful bleed. Failure to do so may result in insufficient fluid volume inside the hydraulic remote system.
    • Draw 20 ml of Reverb hydraulic fluid into the syringe. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe.
  5. How to bleed the RockShox Reverb Stealth: 手順 5、 2の画像 1 How to bleed the RockShox Reverb Stealth: 手順 5、 2の画像 2
    • Remove the bleed screw.
    • Thread the standard syringe bleed fitting into the remote bleed port.
  6. How to bleed the RockShox Reverb Stealth: 手順 6、 3の画像 1 How to bleed the RockShox Reverb Stealth: 手順 6、 3の画像 2 How to bleed the RockShox Reverb Stealth: 手順 6、 3の画像 3
    • Draw 5 ml of fluid into the second RockShox bleed syringe. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe.
    • Remove the bleed screw at the seat post and thread the standard syringe bleed fitting into the seat post bleed port.
    • Depress the remote syringe plunger while pulling the seatpost syringe plunger out.
    • Do not empty the syringe. Leave at least 5 ml of fluid in each syringe during the procedure to avoid air entering the system.
    • Depress the seatpost syringe plunger while pulling the remote syringe plunger out. Repeat these steps until bubbles are no longer pulled from the remote and seatpost.
  7. How to bleed the RockShox Reverb Stealth: 手順 7、 2の画像 1 How to bleed the RockShox Reverb Stealth: 手順 7、 2の画像 2
    • Remove the syringe from the seat post. Install the bleed screw and tighten it. Spray isopropyl alcohol on the seatpost and hydraulic hose and clean them with a shop towel.
    • Pull up on the syringe plunger and push the remote actuator. Depress the syringe plunger until the actuator fully extends. Repeat this process until bubbles are no longer pulled from the remote into the syringe. Then remove the syringe. Install the bleed screw and tighten it. Spray isopropyl alcohol on the remote and clean it with a shop towel.
終わりに
To reassemble your bike, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
メンバー登録日: 11/23/16
229,498 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,455のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 54
今までの合計 7,421
