メインコンテンツにスキップ
HP Stream x360 11-p015wm Keyboard Replacement
Megan Waxman
Megan Waxman とその他 2 人の作成者
最終更新日: December 26, 2019
30分
中レベル
If your keyboard has become damaged or broken, this guide will walk you through the steps of replacing the keyboard in an HP Stream x360 11-p015wm. Follow along, step-by-step to safely remove your keyboard and then follow the instruction in reverse to reassemble your laptop with its new keyboard! Be sure to back-up your files before undergoing this repair.
必要な工具と部品
ツール
もっと見る
  1. HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: 手順 1、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Keyboard Replacement: 手順 2、 1の画像 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Keyboard Replacement: 手順 3、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Keyboard Replacement: 手順 4、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Keyboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Keyboard Replacement: 手順 6、 3の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 6、 3の画像 2 HP Stream x360 11-p015wm Keyboard Replacement: 手順 6、 3の画像 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Keyboard Replacement: 手順 7、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 7、 2の画像 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Keyboard Replacement: 手順 8、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 8、 2の画像 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Keyboard Replacement: 手順 9、 3の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 9、 3の画像 2 HP Stream x360 11-p015wm Keyboard Replacement: 手順 9、 3の画像 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Keyboard Replacement: 手順 10、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 10、 2の画像 2
  11. HP Stream x360 11-p015wm Keyboard Replacement: 手順 11、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 11、 2の画像 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
  12. HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: 手順 12、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: 手順 12、 2の画像 2
    • Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
    • Remove the metal bracket.
  13. HP Stream x360 11-p015wm Keyboard Replacement: 手順 13、 1の画像 1
    • Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
  14. HP Stream x360 11-p015wm Keyboard Replacement: 手順 14、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 14、 2の画像 2
    • Use the blue plastic opening tool to pry up the silver keyboard cover.
    • Remove the keyboard cover.
  15. HP Stream x360 11-p015wm Keyboard Replacement: 手順 15、 2の画像 1 HP Stream x360 11-p015wm Keyboard Replacement: 手順 15、 2の画像 2
    • Remove the keyboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Megan Waxman
メンバー登録日: 11/11/19
160 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G3, Stella Fall 2019 IUPUI, Team S2-G3, Stella Fall 2019人のメンバー
IUPUI-STELLA-F19S2G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 268
