メインコンテンツにスキップ
HP Stream x360 11 -p015wm Back Cover Replacement
DaisyHaskell
DaisyHaskell とその他 3 人の作成者
最終更新日: February 7, 2020
5分
中レベル
Use this guide to replace the back cover of your HP Stream x360 11 -p015wm.
The back cover is important for protecting the internal components. A cracked or damage back cover can allow dust and moisture to damage hardware.
If the back cover is being removed to change the battery, click this link. While the back cover is removed, consider using these methods to clean internal hardware.
Before beginning, ensure the device is completely off and disconnect any external power source.
必要な工具と部品
ツール
もっと見る
  1. HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: 手順 1、 2の画像 1 HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11 -p015wm Back Cover Replacement: 手順 2、 1の画像 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11 -p015wm Back Cover Replacement: 手順 3、 2の画像 1 HP Stream x360 11 -p015wm Back Cover Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11 -p015wm Back Cover Replacement: 手順 4、 2の画像 1 HP Stream x360 11 -p015wm Back Cover Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
DaisyHaskell
メンバー登録日: 10/15/18
701 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 UMass Dartmouth, Team S1-G2, Valliere Fall 2018人のメンバー
UMASSD-VALLIERE-F18S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 416
