メインコンテンツにスキップ
HP Stream x360 11-p015wm Battery Replacement
必要な工具と部品
  1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: 手順 1、 2の画像 1 HP Stream x360 11-p015wm Battery Replacement, Back Cover: 手順 1、 2の画像 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Battery Replacement: 手順 2、 1の画像 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Battery Replacement: 手順 3、 2の画像 1 HP Stream x360 11-p015wm Battery Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Battery Replacement: 手順 4、 2の画像 1 HP Stream x360 11-p015wm Battery Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Battery Replacement, Battery: 手順 5、 3の画像 1 HP Stream x360 11-p015wm Battery Replacement, Battery: 手順 5、 3の画像 2 HP Stream x360 11-p015wm Battery Replacement, Battery: 手順 5、 3の画像 3
    • Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
  6. HP Stream x360 11-p015wm Battery Replacement: 手順 6、 3の画像 1 HP Stream x360 11-p015wm Battery Replacement: 手順 6、 3の画像 2 HP Stream x360 11-p015wm Battery Replacement: 手順 6、 3の画像 3
    • Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
    • Remove the wire located on the top side of the battery.
    • All connections should be removed. Simply remove the battery from the computer.
終わりに
作成者
3人の作成者と共同で作成されました。
DaisyHaskell
メンバー登録日: 10/15/18
701 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 UMass Dartmouth, Team S1-G2, Valliere Fall 2018人のメンバー
UMASSD-VALLIERE-F18S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 578
