メインコンテンツにスキップ
HP Stream 11-y010nr Trackpad Replacement
Adam Sitzmann
Adam Sitzmann とその他 3 人の作成者
最終更新日: May 4, 2020
20分
中レベル
Is your HP Stream 11-y010nr trackpad malfunctioning? Do you need to replace your trackpad entirely? First ensure that the issue is not one of the common problems that can be resolved quickly by checking the troubleshooting page here: HP Stream 11-y010nr Troubleshooting
This guide will take you through the process of getting to the trackpad, removing it, replacing it and getting it back to how it was. Be cautious when removing the cover as there are ribbons (thin wires) attached to it. Pulling the cover off with too much force could rip those, damaging the internal hardware.
Prior to starting, ensure the laptop is powered off and is not going to interfere with the process.
必要な工具と部品
ツール
もっと見る
  1. HP Stream 11-y010nr Trackpad Replacement, Keyboard: 手順 1、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement, Keyboard: 手順 1、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement, Keyboard: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Trackpad Replacement: 手順 2、 2の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 2、 2の画像 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Trackpad Replacement: 手順 3、 2の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 3、 2の画像 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Trackpad Replacement: 手順 4、 1の画像 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Trackpad Replacement: 手順 5、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 5、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement: 手順 5、 3の画像 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Trackpad Replacement, Trackpad: 手順 6、 2の画像 1 HP Stream 11-y010nr Trackpad Replacement, Trackpad: 手順 6、 2の画像 2
    • Take the keyboard and flip it over. It will look like the pictures.
    • Use the needle nose tweezer to take off protective tape covering the top left and top right screws.
  7. HP Stream 11-y010nr Trackpad Replacement: 手順 7、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 7、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement: 手順 7、 3の画像 3
    • Unscrew the three 0.2mm top screws with the Phillips #00 Screwdriver.
  8. HP Stream 11-y010nr Trackpad Replacement: 手順 8、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 8、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement: 手順 8、 3の画像 3
    • Unscrew the three 0.3mm screws holding the bottom bracket with the Phillips #00 Screwdriver.
  9. HP Stream 11-y010nr Trackpad Replacement: 手順 9、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 9、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement: 手順 9、 3の画像 3
    • Lift up on the bracket and remove the bracket by lifting up on the metal end as shown.
  10. HP Stream 11-y010nr Trackpad Replacement: 手順 10、 3の画像 1 HP Stream 11-y010nr Trackpad Replacement: 手順 10、 3の画像 2 HP Stream 11-y010nr Trackpad Replacement: 手順 10、 3の画像 3
    • The trackpad is now free to be removed.
    • Remove the trackpad by gently pulling up on the metal piece on the bottom left corner of the trackpad.
終わりに
To reassemble your device, follow these instructions.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Adam Sitzmann
メンバー登録日: 01/26/20
932 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 305
